Hey there
Is it possible to make an inputbox via ilogic where I can change multiple values at once?
I want to fill in my drawing header, and I want to enter it manually
My code this far looks like this:
EmneThing = iProperties.Value("Project", "Description") iProperties.Value("Project", "Description") = InputBox("Emne", "Emne", EmneThing) While iProperties.Value("Project", "Description") = "" iProperties.Value("Project", "Description") = InputBox("Emne", "Emne", EmneThing) End While DelAfThing = iProperties.Value("Summary", "Subject") iProperties.Value("Summary", "Subject") = InputBox("Del af", "Del af", DelAfThing) While iProperties.Value("Summary", "Subject") = "" iProperties.Value("Summary", "Subject") = InputBox("Del af", "Del af", DelAfThing) End While RevisionThing = iProperties.Value("Project", "Revision Number") iProperties.Value("Project", "Revision number") = InputBox("Revision", "Revision", RevisionThing) While iProperties.Value("Project", "Revision Number") = "" iProperties.Value("Project", "Revision number") = InputBox("Revision", "Revision", RevisionThing) End While GodkendtThing = iProperties.Value ("Project", "Authority") iProperties.Value("Project", "Authority") = InputBox("Godkendt af", "Godkendt af", GodkendtThing) While iProperties.Value("Project", "Authority") = "" iProperties.Value("Project", "Authority") = InputBox("Godkendt af", "Godkendt af", GodkendtThing) End While InventorVb.DocumentUpdate()
It causes four boxes in a row, whereas I would prefer one - If possible
Hello Yannick,
isn´t it possible to make a form for filling all parameters?
The form can be fired with the command:
iLogicForm.Show()
Greetz
It is possible, yes - I couldn't get it to fire a global form, though.
Is there anything special I have to do to make it fire a global form?
Is there a different option these days?
I want to trigger my code automatically, but if I were to open a form via my code, the code wouldn't "pause" like it does for input boxes.
Does anyone have a solution for this?
