Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Import AutoCAD 3DFACES to Solid
2 REPLIES 2
335 Views, 2 Replies
Hi all,
Here is my goal, Import AutoCAD 3DFACES to Solid
1) The Import routine is ok.
2) Then I would like to convert my 6 faces into a solid body
     In Inventor GUI "Repair/Stich" works fine, but API doesn't seem to expose a Stich method...
The best I obtain is Creating a "NonParametricBaseFeature",
But then the KnitFeature best response is "The method as failed". It works fine in the GUI.
I'm on Win7 x64 VBA (Then I will convert it to a lovely DotNet AddIn)
Here is my code:
Sub CreateNonParametricFeature(oDef As ComponentDefinition, oSrfBodies As SurfaceBodies)
    ' Create a non-parametric base feature based on the transient body.
    Dim oTransBRep As TransientBRep
    Set oTransBRep = oInvApp.TransientBRep
    Dim oFeatureDef As NonParametricBaseFeatureDefinition
    Set oFeatureDef = oDef.Features.NonParametricBaseFeatures.CreateDefinition
    Dim oCollection As ObjectCollection
    Set oCollection = oInvApp.TransientObjects.CreateObjectCollection
    oCollection.Add oSrfBodies.Item(1)
    oFeatureDef.BRepEntities = oCollection
    oFeatureDef.OutputType = kCompositeOutputType
    Dim oBaseFeature As NonParametricBaseFeature
    Set oBaseFeature = oDef.Features.NonParametricBaseFeatures.AddByDefinition(oFeatureDef)
    'Knitting the NonParametricBaseFeature
    Dim oFacesCollection As ObjectCollection
    Set oFacesCollection = oInvApp.TransientObjects.CreateObjectCollection
    Dim I As Integer
    For I = 1 To oBaseFeature.SurfaceBodies.Count
        Call oFacesCollection.Add(oBaseFeature.SurfaceBodies.Item(I))
    Next I
    Dim oKnitFeature As KnitFeature
    Set oKnitFeature = oDef.Features.KnitFeatures.Add(oFacesCollection)
End Sub
The Knit sample help code works, but not mine Smiley Frustrated Is there a bug somewhere in my code?
Michel
2 REPLIES 2
ekinsb
I've verified that this is a problem.  I've raised the priority of the change request, but can't say when a solution might be available.
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
in reply to: ekinsb
Hi Brian,
Will you tell us in this thread when a solution will be available, or do we need to check for SPs content?
Cheers,
Michel.
