Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic View Representation
16 REPLIES 16
Message 1 of 17
6755 Views, 16 Replies
I have several assemblies that have invisible parts in them. When I place these assemblies into a parent assembly and toggle the visability off/on my invisible parts show up. Is there an iLogic code I could run that would activate the default view representation in all of those assemblies instead of the default "Master" view rep? Here is the code I've written so far:
Dim aDoc As AssemblyDocument
aDoc = ThisApplication.ActiveDocument
Dim iDoc As Document
For Each iDoc In aDoc.AllReferencedDocuments
Dim ocompdef As ComponentDefinition
ocompdef = iDoc.ComponentDefinition
ocompdef.RepresentationsManager.DesignViewRepresentations.Item("TEST").Activate
Next
Any help would be greatly appreciated.I've also attached photos
16 REPLIES 16
Message 2 of 17
"SetDesignViewRepresentation" works for setting occurance view in an assembly.
Dim doc as AssemblyDocument = ThisDoc.Document
Dim oAsmCompDef As ComponentDefinition
oAsmCompDef = doc.ComponentDefinition
Dim oCompOcc As Inventor.ComponentOccurrence
For Each oCompOcc in oAsmCompDef.Occurrences
oCompOcc.SetDesignViewRepresentation("Default", True)
Next
ThisApplication.ActiveView.Fit
Message 3 of 17
Thank you very much that is exactly what I'm looking for.
Message 4 of 17
As a follow up, that code worked for a while but infrequently I get this error message.1.png
Message 5 of 17
jtylerbc
I took a look at this code because it seemed similar to something I've been looking for a way to do.  I think you are seeing that error message because the view representation you are trying to set doesn't exist in some of the files.
In particular, the code that Carthik_Babu provided references the "Default" view representation.  There is a Default view rep in assemblies, but there is not a representation by that name in part files unless you have created it yourself.
Message 6 of 17
jtylerbc
Carthik_Babu,
How is your code intended to work?
I have been looking for a way to set all components in an assembly to a particular view representation and set them as Associative.  When I was first looking at your posted code, I thought that was what it would do, but my results were different.
Instead, what I actually seem to be getting is that the components get an assembly-level appearance override that matches the color of the target view representation, but the representation of the component actually gets set to Master.  Is that the way this is supposed to behave?
FYI, I'm still running Inventor 2013 here.  If this is something that doesn't work properly without 2014 I can just wait to implement it until our next upgrade
Message 7 of 17
in reply to: jtylerbc
I using inventor 2012 and this code is supposed to take all subassemblies that are set to "Master" and set them to be "Default". I have a lot of invisible parts in my assemblies therefore when the subassemblies get set to "Master" they show all parts even the invisible ones. I found a fix to the error message I was getting because I think you're right when it found a part file it will try to set it to "Default" view rep even when one doesn't exist in the part file.
Dim doc As AssemblyDocument = ThisDoc.Document
oCompOcc.SetDesignViewRepresentation("Default",, True)
On Error Resume Next
Next
Message 8 of 17
jtylerbc
Not sure why, but this message posted blank at first.  Hopefully this time it will work.
I was trying to modify the code to accomplish something I've been looking for a way to do for a while.  It almost (but not quite) worked, which is what my questions were regarding.  While trying to do so, I changed the name of the view rep in the code to my intended one, and the error went away.
If you actually need your code to set assemblies to Default and parts to Master, you could use an If/Then to check whether the component is an assembly or part file, and set the view rep accordingly.
Message 9 of 17
philshields05
I ran into this problem again some months later and you're right you need to distinguish between "Part" and "Assembly" occurences therefore I came up with the following code:
oAsmCompDef = aDoc.ComponentDefinition
If iDoc.SubType = "{E60F81E1-49B3-11D0-93C3-7E0706000000}" Then
Else
End If
Next
 Let me know if this helps you out any.
Message 10 of 17
in reply to: philshields05
Not sure if you needed this still but I finally figured out how to properly distinguish between a component occurence subassembly and part(it also makes sure the components that are visible get changed to "default" and not the ones I've made invisible or "suppressed"):
	If oCompOcc.Visible = True Then
		If oCompOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
		Else
		End If
	Else
	End If
Next
Message 11 of 17
jR0sal3s
i tried to copy and paste your code in a vba environment (Inventor 2017)...it has issues with "oCompOcc.SetDesignViewRepresentation("Default", True)"
Message 12 of 17
jR0sal3s
in reply to: jR0sal3s
Finally...tweak it a bit to run in VBA environment..well at least for anybody, who may still find this useful...
Public Sub test_VRSubComponent()
Set aDoc = ThisApplication.ActiveDocument
Set oAsmCompDef = aDoc.ComponentDefinition
For Each oCompOcc In oAsmCompDef.Occurrences
Call oCompOcc.SetDesignViewRepresentation("SH - MB", , True)
Else
End If
Else
End If
Next
End Sub
Message 13 of 17
jR0sal3s
Else
End If
Else
End If
Next
End Sub
Message 14 of 17
RoyWickrama_RWEI
Your code was helpful. Thanks.
It does well, I suggest you accept it as a solution. It will be highlighted with the green border and more viewers look at it.
Message 15 of 17
jR0sal3s
in reply to: RoyWickrama_RWEI
Thanks. But i couldnt
Message 16 of 17
jR0sal3s
Thanks. But i couldnt nad m glad it helps somehow
Message 17 of 17
KenVaessen
'Representation op Configurator en associative
Else
End If
Else
End If
Next
