Inventor Customization
Valued Contributor
abilabib
Message 1 of 11 (727 Views)
iLogic Update iProperties
727 Views, 10 Replies
11-01-2010 10:43 PM
How to update iLogic 2010 rule for iProperties because I always need regen all rule for get correct statment. in iLogic 2011 its not problem because have event iProperties Change. So I wondering how to create code or what should I do with iLogic 2010 for Automatically update iProperties ?
Employee
MjDeck
Message 2 of 11 (705 Views)
Re: iLogic Update iProperties
11-02-2010 01:36 PM in reply to: abilabib
In Inventor 2010, you can attach the rule to the Before Save Document event.  That will update your properties when you save the file. Is that good enough?
Mike Deck
Software Developer
DLS - Mechanical Design
Autodesk, Inc.
Valued Contributor
abilabib
Message 3 of 11 (699 Views)
11-02-2010 05:59 PM in reply to: abilabib
I think no. Because I must make sure the properites is correct.
here's my rule :
1. input data BOM
'input Item Number
iProperties.Value
("Project", "Part Number") = ItemNumber
'Input Material
MultiValue.List
("Material") = iProperties.Materials
'Input Description
Description
= iProperties.Value ("Project", "Description")
'Input Dimension
Dimension
= iProperties.Value("Custom", "DIMENSION")
'Input Dwg Number
DwgNumber
= TankCode & "-" & ItemNumber
iProperties.Value
("Custom", "DRAWING NO") = DwgNumber
'Display item Description
ItemDesc
= iProperties.Value("Custom", "ITEM DESCRIPTION")
'Display Stock Number
StockNumber
= iProperties.Value("Project", "Stock Number")
'Input Project Number
iProperties.Value
("Project", "Project") = ProjectNumber
iLogicVb.UpdateWhenDone
= True
2. ItemDescription
If
ItemNumber = "110"
Then
iProperties.Value
("Custom", "ITEM DESCRIPTION") =
"SHELL"
ElseIf
ItemNumber = "111"
Then
iProperties.Value
"SHELL 2"
ElseIf
ItemNumber = "120"
Then
iProperties.Value
"TOP DISHED HEAD"
ElseIf
ItemNumber = "130"
Then
iProperties.Value
"BOTTOM DISHED HEAD"
ElseIf
ItemNumber = "132"
Then
iProperties.Value
"INNER BOTTOM CONE"
ElseIf
ItemNumber = "140"
Then
iProperties.Value
"SUPPORT SKIRT"
ElseIf
ItemNumber = "141"
Then
iProperties.Value
"SUPPORT LEG"
ElseIf
ItemNumber = "150"
Then
iProperties.Value
"LIFTING LUG"
ElseIf
ItemNumber = "160"
Then
iProperties.Value
"NAME PLATE TPSE"
ElseIf
ItemNumber = "170"
Then
iProperties.Value
"JACKET"
ElseIf
ItemNumber = "180"
Then
iProperties.Value
"OUTER SHELL"
ElseIf
ItemNumber = "181"
Then
iProperties.Value
"OUTER SHELL 2"
ElseIf
ItemNumber = "182"
Then
iProperties.Value
"REINFORCEMENT RING"
ElseIf
ItemNumber = "183"
Then
iProperties.Value
"INSULATION ROCKWOOL"
ElseIf
ItemNumber = "190"
Then
iProperties.Value
"INSULATION COVER PART"
ElseIf
ItemNumber = "200"
Then
iProperties.Value
"PLATFORM SKIRT"
ElseIf
ItemNumber = "220"
Then
iProperties.Value
"PACKING SKID"
ElseIf
ItemNumber = "300"
Then
iProperties.Value
"MANHOLE"
ElseIf
ItemNumber = "310"
Then
iProperties.Value
"GLASS WITH WIPER"
ElseIf
ItemNumber = "320"
Then
iProperties.Value
"SIGHT GLASS WITH LAMP"
ElseIf
ItemNumber = "330"
Then
iProperties.Value
"ROTARY SPRAY BALL"
ElseIf
ItemNumber = "340"
Then
iProperties.Value
"ROTARY JET HEAD"
ElseIf
ItemNumber = "350"
Then
iProperties.Value
"NON FOAMING INLET"
ElseIf
ItemNumber = "360"
Then
iProperties.Value
"SIDE CIP FLUSH VALVE"
ElseIf
ItemNumber = "370"
Then
iProperties.Value
"SAMPLING VALVE"
ElseIf
ItemNumber = "380"
Then
iProperties.Value
"CONNECTION WITH INSTRUMENT"
ElseIf
ItemNumber = "400"
Then
iProperties.Value
"AGITATOR UNIT"
ElseIf
ItemNumber = "500"
Then
iProperties.Value
"HOMOGENIZER UNIT"
= True
When i change item number, item description isn't changed correctly. I must regen all rule for get the correct item number.
Can u explain me how to solve this problem in ilogic 2010.
thanks,
Abi Labib
Employee
MjDeck
Message 4 of 11 (697 Views)
11-02-2010 06:06 PM in reply to: abilabib
Where are you getting the value called itemNumber?  Is it a numeric or text parameter?  Is it from an Excel spreadsheet?
Can you attach a sample part?
Mike Deck
Software Developer
Autodesk, Inc.
Valued Contributor
abilabib
Message 5 of 11 (692 Views)
11-02-2010 08:43 PM in reply to: abilabib
From string parameter.
Employee
MjDeck
Message 6 of 11 (669 Views)
11-03-2010 08:37 AM in reply to: abilabib
If you use the iLogic Parameters dialog (in Inventor 2010) to change the String parameter named ItemNumber, both those rules should run and your iProperties should update.   Can you post the part, or maybe a simplified version of it (without geometry)?
Mike Deck
Software Developer
Autodesk, Inc.
Valued Contributor
abilabib
Message 7 of 11 (655 Views)
11-03-2010 05:58 PM in reply to: abilabib
Here's My part.
Employee
MjDeck
Message 8 of 11 (649 Views)
11-03-2010 08:40 PM in reply to: abilabib
This will work in Inventor 2010 if you change the order of the rules.  In the iLogic Tree Editor, drag the ItemDescription rule to the top, before the InputDataBOM rule.  You have to hit OK to make the reorder take effect.
 This is required because the ItemDescription rule changes the custom ITEM DESCRIPTION property, which is then used as an input to the InputDataBOM rule.
Mike Deck
Software Developer
Autodesk, Inc.
Valued Contributor
abilabib
Message 9 of 11 (644 Views)
11-03-2010 10:42 PM in reply to: abilabib
Thank you mike for ur explaination. But 1 problem again about StockNumber. This properties can't update with correct. I have change the rule position but still get wrong properties.
Can u explain Me Mike.
Thank,
Abi Labib
Employee
MjDeck
Message 10 of 11 (633 Views)
11-04-2010 09:16 AM in reply to: abilabib
Abi,
 Remove the line:
DwgNumber = TankCode & "-" & ItemNumber
from the InputDataBOM rule.  Move this line to the top of the ItemDescription rule.  (Or you could create a new rule and add this line there.)  This will ensure that the DwgNumber is up to date when the InputDataBOM rule runs.
Mike Deck
Software Developer
Autodesk, Inc.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
