Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic Update iProperties
10 REPLIES 10
Message 1 of 11
abilabib
1188 Views, 10 Replies
How to update iLogic 2010 rule for iProperties because I always need regen all rule for get correct statment. in iLogic 2011 its not problem because have event iProperties Change. So I wondering how to create code or what should I do with iLogic 2010 for Automatically update iProperties ?
10 REPLIES 10
Message 2 of 11
MjDeck
in reply to: abilabib
In Inventor 2010, you can attach the rule to the Before Save Document event.  That will update your properties when you save the file. Is that good enough?
Mike Deck
Software Developer
Autodesk, Inc.
Message 3 of 11
abilabib
I think no. Because I must make sure the properites is correct.
here's my rule :
1. input data BOM
'input Item Number
iProperties.Value
("Project", "Part Number") = ItemNumber
'Input Material
MultiValue.List
("Material") = iProperties.Materials
'Input Description
Description
= iProperties.Value ("Project", "Description")
'Input Dimension
Dimension
= iProperties.Value("Custom", "DIMENSION")
'Input Dwg Number
DwgNumber
= TankCode & "-" & ItemNumber
iProperties.Value
("Custom", "DRAWING NO") = DwgNumber
'Display item Description
ItemDesc
= iProperties.Value("Custom", "ITEM DESCRIPTION")
'Display Stock Number
StockNumber
= iProperties.Value("Project", "Stock Number")
'Input Project Number
iProperties.Value
("Project", "Project") = ProjectNumber
iLogicVb.UpdateWhenDone
= True
2. ItemDescription
If
ItemNumber = "110"
Then
iProperties.Value
("Custom", "ITEM DESCRIPTION") =
"SHELL"
ElseIf
ItemNumber = "111"
Then
iProperties.Value
"SHELL 2"
ElseIf
ItemNumber = "120"
Then
iProperties.Value
"TOP DISHED HEAD"
ElseIf
ItemNumber = "130"
Then
iProperties.Value
"BOTTOM DISHED HEAD"
ElseIf
ItemNumber = "132"
Then
iProperties.Value
"INNER BOTTOM CONE"
ElseIf
ItemNumber = "140"
Then
iProperties.Value
"SUPPORT SKIRT"
ElseIf
ItemNumber = "141"
Then
iProperties.Value
"SUPPORT LEG"
ElseIf
ItemNumber = "150"
Then
iProperties.Value
"LIFTING LUG"
ElseIf
ItemNumber = "160"
Then
iProperties.Value
"NAME PLATE TPSE"
ElseIf
ItemNumber = "170"
Then
iProperties.Value
"JACKET"
ElseIf
ItemNumber = "180"
Then
iProperties.Value
"OUTER SHELL"
ElseIf
ItemNumber = "181"
Then
iProperties.Value
"OUTER SHELL 2"
ElseIf
ItemNumber = "182"
Then
iProperties.Value
"REINFORCEMENT RING"
ElseIf
ItemNumber = "183"
Then
iProperties.Value
"INSULATION ROCKWOOL"
ElseIf
ItemNumber = "190"
Then
iProperties.Value
"INSULATION COVER PART"
ElseIf
ItemNumber = "200"
Then
iProperties.Value
"PLATFORM SKIRT"
ElseIf
ItemNumber = "220"
Then
iProperties.Value
"PACKING SKID"
ElseIf
ItemNumber = "300"
Then
iProperties.Value
"MANHOLE"
ElseIf
ItemNumber = "310"
Then
iProperties.Value
"GLASS WITH WIPER"
ElseIf
ItemNumber = "320"
Then
iProperties.Value
"SIGHT GLASS WITH LAMP"
ElseIf
ItemNumber = "330"
Then
iProperties.Value
"ROTARY SPRAY BALL"
ElseIf
ItemNumber = "340"
Then
iProperties.Value
"ROTARY JET HEAD"
ElseIf
ItemNumber = "350"
Then
iProperties.Value
"NON FOAMING INLET"
ElseIf
ItemNumber = "360"
Then
iProperties.Value
"SIDE CIP FLUSH VALVE"
ElseIf
ItemNumber = "370"
Then
iProperties.Value
"SAMPLING VALVE"
ElseIf
ItemNumber = "380"
Then
iProperties.Value
"CONNECTION WITH INSTRUMENT"
ElseIf
ItemNumber = "400"
Then
iProperties.Value
"AGITATOR UNIT"
ElseIf
ItemNumber = "500"
Then
iProperties.Value
"HOMOGENIZER UNIT"
= True
When i change item number, item description isn't changed correctly. I must regen all rule for get the correct item number.
Can u explain me how to solve this problem in ilogic 2010.
thanks,
Abi Labib
Message 4 of 11
MjDeck
Where are you getting the value called itemNumber?  Is it a numeric or text parameter?  Is it from an Excel spreadsheet?
Can you attach a sample part?
Mike Deck
Software Developer
Autodesk, Inc.
Message 5 of 11
abilabib
From string parameter.
Message 6 of 11
MjDeck
If you use the iLogic Parameters dialog (in Inventor 2010) to change the String parameter named ItemNumber, both those rules should run and your iProperties should update.   Can you post the part, or maybe a simplified version of it (without geometry)?
Mike Deck
Software Developer
Autodesk, Inc.
Message 7 of 11
abilabib
Here's My part.
Message 8 of 11
MjDeck
This will work in Inventor 2010 if you change the order of the rules.  In the iLogic Tree Editor, drag the ItemDescription rule to the top, before the InputDataBOM rule.  You have to hit OK to make the reorder take effect.
 This is required because the ItemDescription rule changes the custom ITEM DESCRIPTION property, which is then used as an input to the InputDataBOM rule.
Mike Deck
Software Developer
Autodesk, Inc.
Message 9 of 11
abilabib
Thank you mike for ur explaination. But 1 problem again about StockNumber. This properties can't update with correct. I have change the rule position but still get wrong properties.
Can u explain Me Mike.
Thank,
Abi Labib
Message 10 of 11
MjDeck
Abi,
 Remove the line:
DwgNumber = TankCode & "-" & ItemNumber
from the InputDataBOM rule.  Move this line to the top of the ItemDescription rule.  (Or you could create a new rule and add this line there.)  This will ensure that the DwgNumber is up to date when the InputDataBOM rule runs.
Mike Deck
Software Developer
Autodesk, Inc.
Message 11 of 11
abilabib
Hi Mike,
Thanks for your explanation. It's solve now. Nice to meet you.
regards,
Abi Labib
