Hi all,
I´m having a bit of an issue with a form.
I have a global form which is exactly made for a specific assembly for configuration of this very assembly. To make things easier for the user I call another external rule which only opens exactly this assembly.
Now when the user opens the form the assembly is not open and obviously can´t reference the used parameters.
Even after loading the assembly the parameters are not available, which results in something like this:
So this is a really simple question, is there a way to update a form so that it rereads the parameters from the assembly?
What I tried is using iLogicForm.CloseGlobal("Name of form") to no availability and then open it again with iLogicForm.ShowGlobal("Name of form").
But I couldn´t find any further info on the iLogicForm Commands.
Cheers Falk
Hi there,
thanks for your response. I do understand what you´re suggesting but hoped I would be able to do an update so the form gets the actual parameters from the assembly.
I´m still not done with your example (had to work on something else), but will give feedback if it´s working.
Now to clear things up a bit my workflow goes like this.
User opens up an external form which is using an external rule that only loads the design template (assembly) which is triggered with a button on that form.
On the following tabs I have parameters which only exist in the design template assembly and since I´m opening the form before the assembly no parameter get´s loaded.
After I´ve loaded the assembly nothing get´s updated on the form since I believe it loads all parameters the first time it opens up.
I think your approach is probably the easiest way to solve my problem.
