I've created a rule to check for fully constrained sketches. The problem seems to be that projected geometry is not being recognized as fully constrained.
I was wondering if anyone would happen to know if this is a bug, or if I am just overlooking something. I've attached a simple part (Inventor 2010) containing the rule.
Thanks in advance,
Curtis
>>> Migrate Inventor Add-ins to 2025 .Net ( from .Net Framework) <<<
Forum links: Inventor iLogic , API and Customization Forum | Inventor Ideas Forum | General Inventor Forum
Solved by MjDeck. Go to Solution.
Curtis,
This is a known issue (internal number 1011232).
Note that it's not saying that the sketch is underconstrained: it's saying that the status is unknown. The ConstraintStatus property is ConstraintStatusEnum.kUnknownConstraintStatus. It seems like it is not looking into the sketch in enough detail to get the actual constraint status.
Thanks for looking into this Mike.
Hi Curtis,
I realise it's been a while since you posted this but would you mind sharing the ilogic routine you created to do this?
Alex.
Hi AlexF1980,
There is a rule in the part file that is attached to the first post of this thread that contains the code, you can use this to see the original issue. But here is the code as well (in case it helps someone find this in a search at some point in the future).
I hope this helps.
Curtis
Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument 'kFullyConstrainedConstraintStatus = 51713 'kUnderConstrainedConstraintStatus = 51714 'kOverConstrainedConstraintStatus = 51715 'kUnknownConstraintStatus = 51716 'i for counter Dim i As Long i = 0 'iterate through each sketch in the part Dim oSketch As PlanarSketch For Each oSketch In oPartDoc.ComponentDefinition.Sketches 'check for sketches that are not Fully constrained If oSketch.ConstraintStatus <> 51713 Then 'increment count by 1 for each undersconstrained sketch found i = i + 1 'create a selection set Dim oSS As SelectSet oSS = ThisApplication.ActiveDocument.SelectSet 'make sure nothing is selected oSS.Clear 'select the current sketch oSS.Select(oSketch) 'find the sketch in the browser Dim oControlDef As ControlDefinition oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppFindInBrowserCtxCmd") oControlDef.Execute 'display message MessageBox.show(oSketch.Name & " is not fully constrained." , _ "ilogic",MessageBoxButtons.OK,MessageBoxIcon.Exclamation) oSS.Clear End If Next oSketch 'display count message if i = 1 then MessageBox.show("A total of "& i & " sketch is not fully constrained.", "ilogic", _ MessageBoxButtons.OK,MessageBoxIcon.Exclamation) else if i > 1 then MessageBox.show("A total of "& i & " sketches are not fully constrained.", "ilogic", _ MessageBoxButtons.OK,MessageBoxIcon.Exclamation) else if i < 1 then 'do nothing end if '--collapse all browser nodes back 'Set a reference to the top node of the active browser Dim oTopNode As BrowserNode oTopNode = oPartDoc.BrowserPanes.ActivePane.TopNode Dim oNode As BrowserNode For Each oNode In oTopNode.BrowserNodes ' If the node is visible and expanded, collapse it. If oNode.Visible = True And oNode.Expanded = True Then oNode.Expanded = False End If Next
Hi Curtis,
Thanks for the code; I had overlooked the file you originally posted.
Do you know if the projected geometry issue was ever fixed? I am using Inventor 2013 so I would assume it *must* have been dealt with by now?
EDIT: Having just ran the code on an Inventor 2013 part file with upwards of 50 sketches, even those sketches that did have the "fully constrained" drawing pin symbol but had projected geometry in them were shown to be under constrained.
I'm going to take a wild stab in the dark and say that the issue hasn't been fixed yet. WTF!?
here are the results of my research this morning:
With a part file containing 3 sketches, one completely unconstrained, the 2nd using projected geometry from the first (so fully constrained for all intents & purposes) and a third sketch fully dimensioned and constrained about the centre point, it seems this issue is alive and well.
Here follows a VBA snippet I created with help from the Inventor "Programming Help" file which will show you exactly what I mean:
Public Sub MoveSketchObjects() ' Check to make sure a sketch is open. If Not TypeOf ThisApplication.ActiveEditObject Is Sketch Then MsgBox ("A sketch must be active.") Exit Sub End If ' Set a reference to the active sketch. Dim oSketch As Sketch Set oSketch = ThisApplication.ActiveEditObject Dim oSketchObjects As ObjectCollection Set oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection ' Get all entities in the sketch Dim oSketchEntity As SketchEntity For Each oSketchEntity In oSketch.SketchEntities If Not oSketchEntity.[_GeometryMoveableStatus] = kFixedGeometryMoveableStatus Then If Not oSketchEntity.ConstraintStatus = kFullyConstrainedConstraintStatus Then oSketchObjects.Add oSketchEntity End If End If Next If oSketchObjects.Count > 0 Then ' the sketch has unconstrained objects and is broken? MsgBox ("this sketch needs some constraints!") Else MsgBox ("Nothing to see here, move along!") End If End Sub
Oddly, even when I run this code in iLogic, it still presents that all three sketches need constraints added to them which isn't the case. What am I missing?
(Attached are my Inventor 2013 part file and the above code in iLogic format)
Alex,
It will work if you add the lines:
Imports Inventor.ConstraintStatusEnum
Imports Inventor.GeometryMoveableStatusEnum
at the top of the rule. These are required to get the values for kFixedGeometryMoveableStatus and kFullyConstrainedConstraintStatus.
Whenever you copy VBA code that has an Inventor enum constant (starting with a k), search for the name in the Inventor help. That will give you the enum type name. Add that to the rule in an Imports statement.
Thanks Mike, that makes perfect sense now that you have said it.
This sort of useful tip needs to be shouted from the rooftops as I am sure I am not the only who has fallen foul of it.
It surprises me that Inventor completely ignores that those two imports were missing from the ilogic code- are there plans for better debugging/error catching of iLogic code?
By default, iLogic sets the VB option
Option Explicit Off
This allows you to use variables without declaring them. We did it this way for ease of use and VBA compatibility. But a downside is that you don't get an error message for Enum constants that are not found.
You will get the compiler error messages if you add
Option Explicit On
Hi...
Can you please help me .... I have also same problem of not getting projected geometry detected for identofying sketch status.
I want to write a program in VB not in ilogic....So can you please help me where i was getting wrong.
Below is my code...
Sub changeSketchname()
Dim ptDoc As PartDocument
Dim ptDocDef As PartComponentDefinition
If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
MsgBox "please open a part document"
Exit Sub
End If
Set ptDoc = ThisApplication.ActiveDocument
Set ptDocDef = ptDoc.ComponentDefinition
Dim Sketches As PlanarSketch
Dim prefix As String
MsgBox "Total number of Sketches = " & ptDoc.ComponentDefinition.Sketches.Count
Dim i As Integer
For i = 1 To ptDoc.ComponentDefinition.Sketches.Count
If ptDoc.ComponentDefinition.Sketches.Item(i).ConstraintStatus = kFullyConstrainedConstraintStatus Then
MsgBox ("Sketch" & i & " is fully constrained")
Else
MsgBox ("Sketch" & i & "is not fully constrained")
End If
Next
End Sub
Hi Mike,
I have added the code you have stated above
but I am getting a Syntax error.
Do you know if this code is no longer compatible with Inventor 2014?
Your help is much appreciated.
Mark
@MjDeck wrote:This is a known issue (internal number 1011232). [...] It seems like it is not looking into the sketch in enough detail to get the actual constraint status.
Can this please be fixed? I'm trying to use the rule below to let me know if any sketches are underconstrained, but some sketches with projected geometry are returning "unknown", even if the sketch is fully constrained OR underconstrained.
Dim ruleName As String = "Find Underconstrained Sketches" Dim partDoc As PartDocument = ThisDoc.Document Dim badSketches As New List(Of String) For Each sk As Sketch In partDoc.ComponentDefinition.Sketches If Not sk.ConstraintStatus = ConstraintStatusEnum.kFullyConstrainedConstraintStatus Then badSketches.Add(sk.Name & " (" & sk.ConstraintStatus.ToString & ")") Next If badSketches.Count > 0 Then MessageBox.Show("The following (" & badSketches.Count & ") sketches are not fully constrained: " & vbCr & vbCr & String.Join(vbCr, badSketches), ruleName, MessageBoxButtons.OK, MessageBoxIcon.Exclamation) Else MessageBox.Show("All sketches are fully constrained!", ruleName, MessageBoxButtons.OK, MessageBoxIcon.Information) End If
@DRoam , can you post a part that shows the problem? Or steps to recreate?
The 1011232 issue had a test case with projected geometry, and it looks like that has been resolved in Inventor 2021 or earlier. You might be seeing something that is similar but not identical.
@R.Mabery , can you share code that shows this problem? I don't see it in Inventor 2021.1 build 245. Here's the rule I'm using:
Option Explicit On
Dim compDef As PartComponentDefinition = partDoc.ComponentDefinition
For Each pSketch As PlanarSketch In compDef.Sketches
Logger.Info(" --------- Sketch: " & pSketch.Name)
For Each ent As SketchEntity In pSketch.SketchEntities
If ent.ConstraintStatus <> ConstraintStatusEnum.kFullyConstrainedConstraintStatus Then
Logger.Warn("** entity ConstraintStatus = {0}", ent.ConstraintStatus)
Logger.Info(String.Format(" -- entity box: ({0},{1}) to ({2},{3})", ent.RangeBox.MinPoint.X, ent.RangeBox.MinPoint.Y, ent.RangeBox.MaxPoint.X, ent.RangeBox.MaxPoint.Y))
End If
Next
Next
Mike, there may be something else going on. I ran my code again this morning and it wasn't showing anything as underconstrained. I shut down Inventor (Build 245 2021.1), relaunched, ran it and it was showing underconstrained. I just ran your code against it and got the following:
TRACE|Entering rule: Rule0 (in 20003136.ipt)
INFO| --------- Sketch: Sketch32
INFO| --------- Sketch: Sketch33
INFO| --------- Sketch: Sketch34
INFO| --------- Sketch: Sketch35
INFO| --------- Sketch: Sketch36
WARN|** entity ConstraintStatus = kUnderConstrainedConstraintStatus
INFO| -- entity box: (-4.70236231460293,11.1633474405716) to (-4.70236231460293,11.1633474405716)
INFO| -- entity box: (-6.70363618696533,13.164621312934) to (-6.70363618696533,13.164621312934)
INFO| -- entity box: (-6.70363618696533,11.1633474405716) to (-4.70236231460293,13.164621312934)
INFO| -- entity box: (-12.5767236901446,7.29153380975477) to (-12.5767236901446,7.29153380975477)
INFO| -- entity box: (-12.5767236901446,7.29153380975477) to (-6.70363618696533,13.164621312934)
INFO| -- entity box: (-11.6401295473557,6.35493966696592) to (-11.6401295473557,6.35493966696592)
INFO| -- entity box: (-12.5767236901446,6.35493966696592) to (-11.6401295473557,7.29153380975477)
INFO| --------- Sketch: Sketch37
INFO| --------- Sketch: Sketch38
INFO| --------- Sketch: Sketch39
INFO| --------- Sketch: Sketch40
INFO| --------- Sketch: Sketch41
INFO| --------- Sketch: Sketch42
INFO| --------- Sketch: Sketch43
INFO| --------- Sketch: Sketch44
INFO| --------- Sketch: Sketch45
INFO| --------- Sketch: Sketch46
TRACE|Exiting rule: Rule0 (in 20003136.ipt)
Here's my original code:
' Dim oPartDoc As PartDocument
' oPartDoc = ThisApplication.ActiveDocument
' Dim oCompDef As ComponentDefinition
' oCompDef = oPartDoc.ComponentDefinition
' Dim oSketches As PlanarSketches
' oSketches = oCompDef.Sketches
' Dim oSketch As PlanarSketch
' For Each oSketch In oSketches
' If oSketch.ConstraintStatus = kFullyConstrainedConstraintStatus Then
' Logger.Info("Sketch: " & oSketch.Name & " is fully constrained")
' ElseIf oSketch.ConstraintStatus = kOverConstrainedConstraintStatus Then
' Logger.Info("Sketch: " & oSketch.Name & " is over constrained")
' ElseIf oSketch.ConstraintStatus = kUnderConstrainedConstraintStatus Then
' Logger.Info("Sketch: " & oSketch.Name & " is under constrained")
' ElseIf oSketch.ConstraintStatus = kUnknownConstraintStatus Then
' Logger.Info("Sketch: " & oSketch.Name & " is unknown status")
' End If
' Next
Dim oAssy As AssemblyDocument
oAssy = ThisApplication.ActiveDocument
Dim oAssyCompDef as AssemblyComponentDefinition
oAssyCompDef = oAssy.ComponentDefinition
Dim oLeafOccs As ComponentOccurrencesEnumerator
oLeafOccs = oAssyCompDef.Occurrences.AllLeafOccurrences
Dim oOcc As ComponentOccurrence
Dim sNotFullyConstrainedList As New ArrayList
Dim sCompsProcessed As New ArrayList
Dim sOccName as String
Dim sFullFileName as String
Dim sSketchName as String
Dim sConcName as String
For Each oOcc In oLeafOccs
If NOT oOcc.Definition.Type = kWeldsComponentDefinitionObject Then
sOccName = oOcc.Name
sFullFileName = oOcc.Definition.Document.FullFilename
If sCompsProcessed.Contains(sFullFileName) Then
Continue For
Else
sCompsProcessed.Add(sFullFileName)
Logger.Info("sOccName: " & sOccName)
Trace.WriteLine("iLogic: sOccName " & sOccName)
Trace.WriteLine("iLogic: sFullFileName: " & sFullFileName)
oSketches = oOcc.Definition.Sketches
Dim oSketchEntity as SketchEntity
sSketchName = oSketch.Name
sConcName = String.Concat(sFullFileName,"_",sSketchName,"_",oSketch.ConstraintStatus)
For Each oSketchEntity in oSketch.SketchEntities
If NOT oSketchEntity.[_GeometryMoveableStatus] = kFixedGeometryMoveableStatus Then
sConcName = String.Concat(sFullFileName,"_",sSketchName,"_",oSketchEntity.Type,"_",oSketch.ConstraintStatus)
If oSketchEntity.ConstraintStatus = kFullyConstrainedConstraintStatus Then
' Trace.WriteLine("iLogic: Sketch: " & oSketch.Name & " is fully constrained")
ElseIf oSketchEntity.ConstraintStatus = kOverConstrainedConstraintStatus Then
Trace.WriteLine("iLogic: Debug Sketch: " & oSketch.Name & " is over constrained")
If NOT sNotFullyConstrainedList.Contains(sConcName) Then
sNotFullyConstrainedList.Add(sConcName)
End If
ElseIf oSketchEntity.ConstraintStatus = kUnderConstrainedConstraintStatus Then
Trace.WriteLine("iLogic: Debug Sketch: " & oSketch.Name & " is under constrained")
End If
ElseIf oSketchEntity.ConstraintStatus = kUnknownConstraintStatus Then
Trace.WriteLine("iLogic: Debug Sketch: " & oSketch.Name & " is unknown status")
End If
End If
End If
Next
Next
End If
End If
Next
For Each m as String In sNotFullyConstrainedList
Trace.Writeline("iLogic: Not Fully constrained Sketches : " & m)
Next
The logger was introduced in Inventor iLogic 2019.
