Hi All
I've been using some code from Curtis blog:
http://inventortrenches.blogspot.co.uk/2013/03/turn-onoff-all-workfeatures-with-ilogic.html
Great little tip and has got me into using iLogic!
I'm trying to expand on this.
I'm working in the Assembly level of a large model creating Assembly level features. Unfortunately I have the odd work feature or sketch in lower sub assemblies and parts which have mistakenly been left visible. I would like to loop through all the lower sub assemblies and parts to turn the visibility off for these.
The thing which has got me stuck at present, is the view reps! Some of the view reps are on "Master"and thus locked, so my code can't change the visibility of the sketch.
Any help would be great folks!
What I have so far (using Curtis example, thx)
' set a reference to the assembly component definintion. Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'define the Component Occurrence collection Dim oCompOcc As Inventor.ComponentOccurrence 'This assumes an assembly document is open. 'define the active assembly. Dim oAssyDoc As AssemblyDocument oAssyDoc = ThisApplication.ActiveDocument 'create a list to hold the different options. Dim myArrayList As New ArrayList 'add the occurrence name to the list myArrayList.add("WorkPlanes") myArrayList.add("WorkAxes") myArrayList.add("WorkPoints") myArrayList.add("Sketches") myArrayList.add("ALL Work Features") 'present the user with the list to choose from. myComponent = InputListBox("Select an Option."& vbLf & "This will turn visibility OFF for all nested work features.", myArrayList, myArrayList.item(0), "iLogic", "List") 'define the Design View Rep Dim oViewRep As DesignViewRepresentation If myComponent <> "" Then 'set the top view rep to "default". If view rep is on "Master", this is locked and visibility changes wont take effect. For Each oViewRep In oAsmCompDef.RepresentationsManager.DesignViewRepresentations oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Default").activate Next End If 'Check all referenced docs Dim oDoc As Inventor.Document For Each oDoc In oAssyDoc.AllReferencedDocuments If myComponent = "WorkPlanes" Then 'set work plane visibility For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes oWorkPlane.Visible = False Next Else If myComponent = "WorkAxes" Then 'set work axis visibility For Each oWorkAxes In oDoc.ComponentDefinition.WorkAxes oWorkAxes.Visible = False Next Else If myComponent = "WorkPoints" Then 'set work point visibility For Each oWorkPoint In oDoc.ComponentDefinition.WorkPoints oWorkPoint.Visible = False Next Else If myComponent = "Sketches" Then 'set sketch visibility For Each oSketch In oDoc.ComponentDefinition.Sketches oSketch.Visible = False Next Else If myComponent = "ALL Work Features" Then 'Set work plane visibility For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes oWorkPlane.Visible = False Next 'set work axis visibility For Each oWorkAxis In oDoc.ComponentDefinition.WorkAxes oWorkAxis.Visible = False Next 'set work point visibility For Each oWorkPoint In oDoc.ComponentDefinition.WorkPoints oWorkPoint.Visible = False Next 'set sketch visibility For Each oSketch In oDoc.ComponentDefinition.Sketches oSketch.Visible = False Next End If Next 'update the files InventorVb.DocumentUpdate() 'report the result If myComponent = "" Then MessageBox.Show("Cancelled, no work feature visibilities changed.", "iLogic - Turn Work Features OFF") Else MessageBox.Show(myComponent & " now have visibility set to off.", "iLogic - Turn Work Features OFF") End If
Try to achieve exactly the same in the UI, that should give you an idea about what is going wrong.
Looking at your code I think what's missing is that you are working in the the definition of the subassembly (same as if opening it up directly) and so there as well you would need to change to "Default" design view before trying to change the Sketch visibility in the subassembly, and then also change to "Default" design view for the ComponentOccurrence of that subassembly, so the design view where the Sketch is invisible will be shown in the main assembly.
This might be of help to a certain extent: http://adndevblog.typepad.com/manufacturing/2013/07/occurrences-contexts-definitions-proxies.html
Cheers,
