I have created several rules for idw's and set them to fire using the "Before Save Document" event trigger. Basically, they updated the idw properties to match the ipt/iam, set the drawing scale and updated the date. These have been functioning perfectly for the past year, until yesterday, that is.
I have a large assy (1500+ parts and sub-assemblies) that I needed to copy. I used the "Ilogic Design Copy" tool for this, which functioned perfectly. However, after completing this, the aforementioned rules no longer fire for any idw, regardless of project. I have tried the following to get it to work:
I can get each individual rule to fire if I RMB on the rule, select "Edit Rule" and click OK (no edits are made to the rules). However the rules will still not fire using the triggers after I do this. I tested this by changing the part number of the part, and saving, closing and re-opening the file... Nothing.
I saw the the new service pack was available so I installed it in the hopes it might fix the issue... Nothing
Help, please...
Solved by b.mccarthy. Go to Solution.
The large assembly I used the tool for had 75+ sub-assemblies of @10 parts and drawings for each. Did your test used similar parameters?
The issue did not occur when I used the tool for smaller assemblies, although I only tested it on assemblies with less than 50 items, including all parts, subassemblies and drawings. It only occurred with the large assembly.
I was finally able to locate the issue, which I missed before the initial post...
For some reason, the tool un-checked the "Run these rules when events occur" checkbox in the Events Triggers dialog. Why this happened, I would like to know, as I now cannot totally rely on the rule trigger to maintain its setting, and must re-check it for every drawing, an in-efficient process at best.
Thank you for responding...
