I would like to know, whether is there is any ilogic option by which the Custom content center is triggered automatically to insert component in an assembly.
Thanks in advance.
Carthik
Below image shows the process sequence, the way i want to handle in ilogic.
I need the 3rd step to be triggered directly after "selecting the tree by ilogic code", so that selection can be made by user.
Whether it is possible.
I have modified the code from Inventor Help file as below
Sub Main()
PlaceContentCenterPart()
End Sub
Sub PlaceContentCenterPart()
' Set a reference to the active assembly document.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
' Set a reference to the ContentCenter object.
Dim oContentCenter As ContentCenter
oContentCenter = ThisApplication.ContentCenter
' Get the content node (category) "Fasteners:Bolts:Hex Head"
Dim oContentNode As ContentTreeViewNode
oContentNode = oContentCenter.TreeViewTopNode.ChildNodes.Item("Fasteners").ChildNodes.Item("Bolts").ChildNodes.Item("Hex Head")
' Get the "ISO 4015" Family object.
Dim oFamily As ContentFamily
For Each oFamily In oContentNode.Families
If oFamily.DisplayName = "ISO 4015" Then
Exit For
End If
Next
' Create a member based on the first row of the family.
Dim Error1 As MemberManagerErrorsEnum
Dim strContentPartFileName As String
Dim strErrorMessage As String
strContentPartFileName = oFamily.CreateMember(1, Error1, strErrorMessage)
' Dim oMat As Matrix
' oMat = ThisApplication.TransientGeometry.CreateMatrix
' Insert an instance of the content center member in the assembly.
'Call oDoc.ComponentDefinition.Occurrences.Add(strContentPartFileName, oMat)
' Set a reference to the transient geometry object.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
' Create a matrix.
Dim oMatrix As Matrix
oMatrix = oTG.CreateMatrix
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
'place an instance of the component
'in this case at 0,0,0
'positioned at the co-ordinates
oMatrix.SetTranslation(oTG.CreateVector(0, 0, 0))
oOccurrence = oAsmCompDef.Occurrences.Add(strContentPartFileName, oMatrix)
oOccurrence.Grounded = False
End Sub
Note: Autodesk Inventor Version :2011
Carthik
oops....no reply yet.....well....is it possible to trigger "Change Size Option for a particular component" by Ilogic.
Kindly help, need this option badly to reduce my work in Design automation.
Carthik Babu M.S
Hi Carthikm,
I do not see any event for Change Size with iLogic, either does Inventor API. Although UserInputEvents.OnActivateCommand of Inventor API can fire for Change Size, but it does not tell the Change Size command is executed
Probably AssemblyEvents.OnOccurrenceChange of Inventor API could help a bit. i.e. when the event fires, check if it is for the CC part you want to watch.
For example, kindly check the link below.
good day sir,
have you might find a way to program this? (change size in ilogic to change more than only the lenght)
or doesn't inventor have this option jet?
thanks in advance,
Davey
