iLogic to run when assembly component is deleted?
2 REPLIES 2
Allen_Hart
290 Views, 2 Replies
Is it possible to have an iLogic rule that fires when an assembly component is deleted?
When the rule runs I want to also delete the ipt file of that component.
Examples of how to do this would be greatly appreciated.
Allen
2 REPLIES 2
Hi Allen,
Unfortunately I'm pretty sure this isn't doable with iLogic. It isn't really suitable for "advanced" customization involving events. Take a look at the iLogic "Triggers" dialog to get an idea about what iLogic offers to run rules:
Reacting to an occurrence supressed will however be fairly straighforward when using the API, you need to have an add-in deployed for that obviously. In that case you can use the "AssemblyEvents.OnOccurrenceChange" event:
The changes reported by this event are if any of the following states of an occurrence change: grounded, adaptive, visible, enabled, suppressed, and repositioned (transformed). The type of change and information related to the change is passed through the context argument.
(See Help Files for more details).
I hope that helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Thanks Philippe.  That confirms what I suspected.  Was hoping there might be an "easy button"   Smiley LOL
Allen
