Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Ilogic to make a parts BOM structure to Phantom from an assembly rule
5 REPLIES 5
gazadder
1169 Views, 5 Replies
Is it possible to change a parts BOM structure using Ilogic from Normal to Phantom from an assembly rule? I can change a parts BOM Structure to Reference however the problem is the part I require is within a pattern and changing the BOM structure is just changing 1 occurance of the pattern so if there are 12 occurances then only 1 of them is changing to Reference.
The below code is what I am using that doesn't quite do what I want.
oCompOcc = Component.InventorComponent("INNER_STIFFENING_RING​_1")
oCompOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
5 REPLIES 5
Vladimir.Ananyev
in reply to: gazadder
You may change the Bom Structure to Phantom via BOMRow.BOMStructure property.
Could you please look at the following thread?
http://forums.autodesk.com/t5/inventor-customization/bom-structure-fromnormal-to-phantom/m-p/3604844...
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
gazadder
in reply to: Vladimir.Ananyev
Thansk Vladimir
I have seen this thread before but my skill level doesn't let me modify it to be specific to a particular part from within an assembly?
Vladimir.Ananyev
The following method should work:
'get the reference to the component by its name
Dim oOcc As ComponentOccurrence = Component.InventorComponent("INNER_STIFFENING_RING​_1")
' set BOM structure to Phantom
oOcc.Definition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
'oOcc.Definition.BOMStructure = BOMStructureEnum.kNormalBOMStructure 'oOcc.Definition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure 'oOcc.Definition.BOMStructure = BOMStructureEnum.kInseparableBOMStructure
Cheers,
Vladimir Ananyev
gazadder
Many thanks for this Vladimir.
Vladimir.Ananyev
Happy coding!  Smiley Happy
Vladimir Ananyev
