Is it possible to change a parts BOM structure using Ilogic from Normal to Phantom from an assembly rule? I can change a parts BOM Structure to Reference however the problem is the part I require is within a pattern and changing the BOM structure is just changing 1 occurance of the pattern so if there are 12 occurances then only 1 of them is changing to Reference.
The below code is what I am using that doesn't quite do what I want.
oCompOcc = Component.InventorComponent("INNER_STIFFENING_RING_1") oCompOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
Solved by Vladimir.Ananyev. Go to Solution.
You may change the Bom Structure to Phantom via BOMRow.BOMStructure property.
Could you please look at the following thread?
Thansk Vladimir
I have seen this thread before but my skill level doesn't let me modify it to be specific to a particular part from within an assembly?
The following method should work:
'get the reference to the component by its name Dim oOcc As ComponentOccurrence = Component.InventorComponent("INNER_STIFFENING_RING_1") ' set BOM structure to Phantom oOcc.Definition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
'oOcc.Definition.BOMStructure = BOMStructureEnum.kNormalBOMStructure 'oOcc.Definition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure 'oOcc.Definition.BOMStructure = BOMStructureEnum.kInseparableBOMStructure
Cheers,
Happy coding!
