HI All
I am trying to get the vault revision table up and running within our office and all is good except for the wipping of revision table history of revisions that happened before i turned the Vault professional feature on.
To try and get over this i am trying to the following with an ilogic external rule
We then can synk properties from vault and still preserve history.
I can see the benifits of the vault revision history but wipping existing data makes no sense and cause most companys from what i can gather a major headacke.
hopefully someone can advise on this as it will make the justification of turning this feature on worthwhile.
I am not quite sure what the scenario is regarding with Vault, but in Inventor, you can get the information of revision table by API. The help document of Inventor API contains a sample as below. I think it would not be difficult to you to convert it to iLogic.
If I misunderstood your question, could you elaborate with more information, or necessary snapshots/files?
Public Sub RevisionTableQuery()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the first revision table on the active sheet.
' This assumes that a revision table is on the active sheet.
Dim oRevTable As RevisionTable
Set oRevTable = oDrawDoc.ActiveSheet.RevisionTables.Item(1)
' Iterate through the contents of the revision table.
Dim i As Long
For i = 1 To oRevTable.RevisionTableRows.Count
' Get the current row.
Dim oRow As RevisionTableRow
Set oRow = oRevTable.RevisionTableRows.Item(i)
' Iterate through each column in the row.
Dim j As Long
For j = 1 To oRevTable.RevisionTableColumns.Count
' Get the current cell.
Dim oCell As RevisionTableCell
Set oCell = oRow.Item(j)
' Display the value of the current cell.
Next
Next
End Sub
