Ilogic to export rev table and re-insert as std table with formatting
1 REPLY 1
DClunie1
301 Views, 1 Reply
HI All
I am trying to get the vault revision table up and running within our office and all is good except for the wipping of revision table history of revisions that happened before i turned the Vault professional feature on.
To try and get over this i am trying to the following with an ilogic external rule
  1. Export current revision table with all data present
  2. Save in same location of file
  3. Import back into dwg as a table
We then can synk properties from vault and still preserve history.
I can see the benifits of the vault revision history but wipping existing data makes no sense and cause most companys from what i can gather a major headacke.
hopefully someone can advise on this as it will make the justification of turning this feature on worthwhile.
1 REPLY 1
xiaodong_liang
in reply to: DClunie1
I am not quite sure what the scenario is regarding with Vault, but in Inventor, you can get the information of revision table by API. The help document of Inventor API contains a sample as below. I think it would not be difficult to you to convert it to iLogic.
If I misunderstood your question, could you elaborate with more information, or necessary snapshots/files?
Public Sub RevisionTableQuery()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the first revision table on the active sheet.
    ' This assumes that a revision table is on the active sheet.
    Dim oRevTable As RevisionTable
    Set oRevTable = oDrawDoc.ActiveSheet.RevisionTables.Item(1)
    ' Iterate through the contents of the revision table.
    Dim i As Long
    For i = 1 To oRevTable.RevisionTableRows.Count
        ' Get the current row.
        Dim oRow As RevisionTableRow
        Set oRow = oRevTable.RevisionTableRows.Item(i)
        ' Iterate through each column in the row.
        Dim j As Long
        For j = 1 To oRevTable.RevisionTableColumns.Count
            ' Get the current cell.
            Dim oCell As RevisionTableCell
            Set oCell = oRow.Item(j)
            ' Display the value of the current cell.
  1. Print "Row: " & i & ", Column: " & oRevTable.RevisionTableColumns.Item(j).Title & " = "; oCell.Text
        Next
    Next
End Sub
