I have 8 holes each a single feature is there a way for ilogic to count the active ones even if they change to inactive without a ten mile long code?
Hole 1 true
Hole 2 true
Hole 3 true
Hole 4 False
Hole 5 False
Hole 6 False
Hole 7 true
Hole 8 true
Count should be 5
If I change to
Hole 1 true
Hole 2 true
Hole 3 true
Hole 4 False
Hole 5 true
Hole 6 False
Hole 7 true
Hole 8 true
Count should be 6
Hole 1 False
Hole 2 False
Hole 3 False
Hole 4 False
Hole 5 true
Hole 6 False
Hole 7 true
Hole 8 true
Count should be 3
Can this be done with short code?
Many Thanks
Solved by thomaskennedy. Go to Solution.
You can use a For Each Loop to iterate through all the hole features. Something like this should do it :
NoOfHoles = 0 For Each HFeature As HoleFeature In ThisDoc.Document.ComponentDefinition.Features.HoleFeatures If HFeature.Suppressed = False Then NoOfHoles = NoOfHoles + 1 Next HFeature MsgBox(NoOfHoles)
Hope this helps
Tom
This gives me an error "end of statement expected"
Also this will count all holes right? I only need 8 of the holes to be count if they are active or not if it counts all holes it will give me the wrong count.. Unless I minus the others correct?
One more thinfg I want this to go to a ipro in my custom so do I just take out the MsgBox (NoOfHoles)
and put in the code to fill in my custom iproperty?
Yes, that code will count all active hole features.
Yes, change Msgbox(NoOfHoles) to iProperties.Value("Custom", "HoleCount") = NoOfHoles.
Not sure why your're getting an error, did the code paste correctly into your rule?
Tom
ps. There is lots of help and sample code in the 'Programming Help' in Inventor. This is the API help area, which is where you should be looking for this sort of thing.
Note that the examples are given in VBA but it's easy to convert them for use in iLogic.
Yes you can subtract a value from the hole count to give you the count you need (if this is workable for you) otherwise you can do some checks against the hole name.
For example, if you named the holes that need counting "CountMe Hole 1" / "CountMe Hole 2" etc. you could do :
NoOfHoles = 0 For Each HFeature As HoleFeature In ThisDoc.Document.ComponentDefinition.Features.HoleFeatures If HFeature.Suppressed = False Then If Left(HFeature.Name,7) = "CountMe" Then NoOfHoles = NoOfHoles + 1 End If End If Next HFeature iProperties.Value("Custom", "HoleCount") = NoOfHoles
Which will only add the hole to the count if the first 7 chars are "CountMe"
Well hard to say if it pasted right seeing I don't know what it looks like it copied just like you posted.
And API is where I try to get help but I am not having much luck converting it to ilogic.
Could you post your entire rule ? I can't see why it wouldn't work.
Or even better you could post your model...
Im not sure why it didnt work first time, I re copied the code back in and now its working.
I also added a line that checks if the last char of the hole name is a number - if it is a number then it doesnt get added to the count.
Hope this works OK for you.
Just guessing but you where probably just missing the "End If" statement right above the Line that says "Next HFeature". If you where wondering why it wasn't working the first time.
PS - Thanks for the link to this on my post.
