Inventor Customization
*Pro
jletcher
Message 1 of 23 (701 Views)
ilogic to count features
701 Views, 22 Replies
08-14-2012 01:10 PM
I have 8 holes each a single feature is there a way for ilogic to count the active ones even if they change to inactive without a ten mile long code?
Hole 1  true
Hole 2 true
Hole 3 true
Hole 4 False
Hole 5 False
Hole 6 False
Hole 7 true
Hole 8 true
Count should be 5
If I change to
Hole 1  true
Hole 2 true
Hole 3 true
Hole 4 False
Hole 5 true
Hole 6 False
Hole 7 true
Hole 8 true
Count should be 6
Hole 1  False
Hole 2 False
Hole 3 False
Hole 4 False
Hole 5 true
Hole 6 False
Hole 7 true
Hole 8 true
Count should be 3
Can this be done with short code?
Many Thanks
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Im not sure why it didnt work first time, I re copied the code back in and now its working.
I also added a line that checks if the last char of the hole name is a number - if it is a number then it doesnt get added to the count.
Hope this works OK for you.
Distinguished Contributor
thomaskennedy
Message 2 of 23 (685 Views)
Re: ilogic to count features
08-15-2012 01:07 AM in reply to: jletcher
You can use a For Each Loop to iterate through all the hole features. Something like this should do it :
NoOfHoles = 0
For Each HFeature As HoleFeature In ThisDoc.Document.ComponentDefinition.Features.HoleFeatures
	If HFeature.Suppressed = False Then NoOfHoles = NoOfHoles + 1
Next HFeature
MsgBox(NoOfHoles)
Hope this helps
Tom
*Pro
jletcher
Message 3 of 23 (681 Views)
08-15-2012 04:13 AM in reply to: thomaskennedy
This gives me an error "end of statement expected"
James Letcher
*Pro
jletcher
Message 4 of 23 (679 Views)
08-15-2012 04:15 AM in reply to: thomaskennedy
Also this will count all holes right? I only need 8 of the holes to be count if they are active or not if it counts all holes it will give me the wrong count.. Unless I minus the others correct?
James Letcher
*Pro
jletcher
Message 5 of 23 (675 Views)
08-15-2012 04:32 AM in reply to: thomaskennedy
One more thinfg I want this to go to a ipro in my custom so do I just take out the MsgBox (NoOfHoles)
and put in the code to fill in my custom iproperty?
James Letcher
*Pro
jletcher
Message 6 of 23 (666 Views)
08-15-2012 06:43 AM in reply to: jletcher
Autodesk if your not going to step in and help then make samples and help files for ilogic PLEASE.
James Letcher
thomaskennedy
Message 7 of 23 (657 Views)
08-15-2012 08:28 AM in reply to: jletcher
Yes, that code will count all active hole features.
Yes, change Msgbox(NoOfHoles) to iProperties.Value("Custom", "HoleCount") = NoOfHoles.
Not sure why your're getting an error, did the code paste correctly into your rule?
Tom
ps. There is lots of help and sample code in the 'Programming Help' in Inventor. This is the API help area, which is where you should be looking for this sort of thing.
Note that the examples are given in VBA but it's easy to convert them for use in iLogic.
thomaskennedy
Message 8 of 23 (652 Views)
08-15-2012 08:36 AM in reply to: jletcher
Yes you can subtract a value from the hole count to give you the count you need (if this is workable for you) otherwise you can do some checks against the hole name.
For example, if you named the holes that need counting "CountMe Hole 1" / "CountMe Hole 2" etc. you could do :
NoOfHoles = 0
		If Left(HFeature.Name,7) = "CountMe" Then
		End If
	End If
Next HFeature
Which will only add the hole to the count if the first 7 chars are "CountMe"
jdkriek
Message 9 of 23 (651 Views)
08-15-2012 08:37 AM in reply to: thomaskennedy
I attest to that code working in 2011, 2012, and 2013 iLogic :smileywink:
Jonathan D. Kriek
Autodesk Inventor Certified Expert
Microsoft Certified Application Developer
_____________________________________________________
Did I help you? Please choose Accept as Solution or Kudos below
*Pro
jletcher
Message 10 of 23 (649 Views)
08-15-2012 08:38 AM in reply to: thomaskennedy
Well hard to say if it pasted right seeing I don't know what it looks like it copied just like you posted.
And API is where I try to get help but I am not having much luck converting it to ilogic.
James Letcher
