iLogic run rule vb.net
3 REPLIES 3
3266 Views, 3 Replies
I have recently started to write inventor addins in vb.net.
 At the moment try a iLogic rule call. But i cant find an vb.net-example for this here or anywhere else.
I created the rule and now i want to run it.
1530i3A1E1D356BCF17FB
I would be very happy if someone could help me with this problem!
3 REPLIES 3
herrwolf1
   It's not as simple as just running the rule. The following code should get you what you need. I use this code in a third party VB.Net 2008 app. It should work for an addin. I hope this helps.
Private iLogicAuto As Object
Private invApp As Inventor.Application
Public Sub RuniLogicRule(ByVal RuleName As String)
On Error Resume Next
If iLogicAuto Is Nothing Then
iLogicAuto = GetiLogicAutomation(invApp)
End If
If iLogicAuto Is Nothing Then Exit Sub
Dim oDoc As Inventor.Document = invApp.ActiveDocument
iLogicAuto.RunRule(oDoc, RuleName)
oDoc = Nothing
On Error GoTo 0
End Sub
Private Function GetiLogicAutomation(ByVal oApplication As Inventor.Application) As Object
'Get the addins collection
Dim addIns As ApplicationAddIns
addIns = oApplication.ApplicationAddIns
'Find the add-in you are looking for
Dim customAddIn As ApplicationAddIn = Nothing
Dim i As Long
For i = 1 To addIns.Count
If (addIns(i).ShortDisplayName = "iLogic") Then
customAddIn = addIns.Item(i)
Exit For
End If
Next i
If (customAddIn Is Nothing) Then Return Nothing
customAddIn.Activate()
GetiLogicAutomation = customAddIn.Automation
End Function
RuniLogicRule("Update Title Block Rule")
I tried running this with vb.net 2013 and it desn't do anything (doesn't run the rule).
It seems like when it runs the GetIlogicAutomation sub, it does not return the ilogic object... because if I test the value of ilogicauto after it runs that sub, the value is still Nothing.
It also seems that the invapp object isn't being assigned anything?  I am used to doing "invapp=thisapplication" after the dim statement, but vb.net says that "thisapplication" is not declared.
Here is what I have as a class library to call from ilogic itself:
Imports Inventor
Public Class InventorAPI
    Private iLogicAuto As Object = Nothing
        invApp = Application
        End If
        oDoc = Nothing
        On Error GoTo 0
    End Sub
    Function ReadInvParam(ParamName As String) As String
        'If iLogicAuto Is Nothing Then
        'End If
        If iLogicAuto Is Nothing Then Return "Unable to get Ilogic object"
        Return iLogicAuto.ParamValue(oDoc, ParamName)
    End Function
        Dim i As Long
            MsgBox(addIns(i))
                Exit For
            End If
        Next i
        Return customAddIn.Automation
    End Function
End Class
I am then calling that library with:
AddReference "C:\_Vaultwip\vb_addons\InventorAPI.dll"
Dim oLib As New InventorAPI.InventorAPI
MessageBox.Show(oLib.ReadInvParam("test"))
Call oLib.RuniLogicRule("myRule")
 and what I get is that it cannot get the ilogic object, and then nothing.
Thanks!
rjay75
I've actually done something similar to this in C#. You need to assign the Inventor reference to you library.
In your class constructor I would pass the current Inventor Application object to the library like so.
    Public Sub New(ByRef app As Inventor.Application)
      'Set the app to the app supplied by the rule
      invApp = app
      'Set the iLogic Automation
      iLogicAuto = invApp.ApplicationAddins.ItemsById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}").Automation
    End Sub
Dim oDoc As Inventor.Document = invApp.ActiveDocument iLogicAuto.RunRule(oDoc, RuleName) oDoc = Nothing On Error GoTo 0 End Sub Function ReadInvParam(ParamName As String) As String On Error Resume Next Return iLogicAuto.ParamValue(oDoc, ParamName) End Function End Class
In the iLogic rule
Dim oLib As New InventorAPI.InventorAPI(ThisApplication)
