Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic rule
6 REPLIES 6
968 Views, 6 Replies
iLogic rule
Hello,   I'm having trouble creating this iLogic rule.  When in a part - i want to be able to change the title of the part.  When in a drawing - i want to be able to change the title of the drawing en then replace the part title with it.  When i launch the rule in a part i get this error (attachment). When i launch the rule in a drawing, it only updates itsel, which is weird because when i launch the rule without "If doc.DocumentType = kDrawingDocumentObject Then" it works just fine. Any help is welcome.    Rule:  doc = ThisDoc.ModelDocument  Title = InputBox("Enter the title", "Title", iProperties.Value("Summary", "Title"))  iProperties.Value("Summary", "Title") = Title  If doc.DocumentType = kDrawingDocumentObject Then  aModel = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)  iProperties.Value(aModel, "Summary", "Title") = iProperties.Value("Summary", "Title")  End If  InventorVb.DocumentUpdate()    Thanks in advance,  Stan
6 REPLIES 6
ChristinaForest
Hi!
I'm not sure if i understand exactly what you want?
add your files here!  ipt and idw
in reply to: ChristinaForest
I want to be able to change the title of a drawing or part with this one rule. The rule is not for one specific part or drawing, but for basicly all the drawings we have. I'll attach two examples. So I want to be able to do these:
  • When I'm in a drawing and i run the rule: it filles in the Title (iProperties) and then copies the title to the linked part.
  • When I'm in a part and i run the rule: it just filles in the Title. Nothing more.
Problem is, when i run the rule from the part i get this message (attachment).
rjay75
It's because you were using ThisDoc.ModelDocument which in a drawing document returns the part of the first baseview in the document. Use ThisDoc.Document instead.
doc = ThisDoc.Document
in reply to: rjay75
Thanks, it's working in the drawing now. But if i run it in a part it still comes up with the error message.
rjay75
Missed a line. This should use ThisDoc instead of ThisDrawing.
    aModel = IO.Path.GetFileName(ThisDoc.ModelDocument.FullFileName)
in reply to: rjay75
Thanks a lot! And i understand what the problem was so that helps me getting furthur with iLogic, so that's great.
