Haha, little monday morning humour,
So I would like help with a simple rule if anyone has a few moments,
Basically, some of my drawings require a dxf for cnc purposes.
Not all my drawings, so I don't need a dxf for every drawing, just some.
It would be much quicker to have a rule that prompts a message box after I press save, stating something like
Do you require a .DXF?
Yes or No.
I currently have a rule that saves all my .idw's as pdf, I am not sure if I should have a separate rule or if it can be part of the same rule. The pdf rule is triggered by a save as well.
'Save PDF with options path_and_namePDF = ThisDoc.PathAndFileName(False) ' without extension PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then 'oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'Set the destination file name oDataMedium.FileName = path_and_namePDF & ".pdf" On Error Goto handlePDFLock 'Publish document. Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Exit Sub handlePDFLock: MessageBox.Show("PDF could not be saved, most likely someone else has it open.", _ "No PDF for you " & ThisApplication.GeneralOptions.UserName & "!") Resume Next
Thanks for any input!!
I searched this forum and came up with no results for any rules for exporting a dxf. I just did a google search and it found a post from this forum! the same search was done??
Oh well, here is the old post:
They have the following iLogic Rule for exporting to dxf, I have a questioin though, the OP states he has the rule set up to save to specific folder, I would like to save the dxf to the same directory as the .idw. Also i see in the rule he is referencing to an .ini file. What is that .ini file for and do I need it for my application?
Thanks (rule below)
' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Sets directory for file save Dim DXFDirectory As String DXFDirectory = "\\ServerName\Shared\DXF Folder\" ' Sets save name as iProperties value Dim SaveName As String SaveName = iProperties.Value("Project", "Part Number") If Len(Dir(DXFDirectory, vbDirectory)) = 0 Then MkDir (DXFDirectory) End If ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "\\HMI-ENGINEERING\Inventor_Data\Miscellaneous\dxf.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the destination file name oDataMedium.FileName = ThisDoc.PathAndFileName(False) oDataMedium.FileName = DXFDirectory & SaveName & ".dxf" 'Publish document. DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with i = MessageBox.Show("Preview the DXF file?", "DXF Preview",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
Update: the code below now produces a .dxf when I save a drawing.
It uses the same name and places it in the same directory,
The final step I would like, is once I press save on the drawing, I would like a message box to pop up asking if a .dxf export is required, if yes then run the rule, if no then just save document.
I will continue to play around with this tonight and post back if I can find a solution!
' Get the DXF translator Add-In. path_and_nameDXF = ThisDoc.PathAndFileName(False) Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "\\TESSBSRV\Personal\sfarr\Documents\CAD_Documents\DXF_Export_INI\DXF_Export.ini" oOptions.Value("Export_Acad_IniFile") = strIniFile End If oDataMedium.FileName = path_and_nameDXF & ".dxf" Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Victory!
I used this reference to complete my rule, works great now:
http://inventortrenches.blogspot.ca/2011/03/using-yes-no-message-box-in-your-ilogic.html
Below is a rule that I have triggered by a save, once the drawing is saved a message box prompts asking if a .dxf is needed, yes or no. if yes is selected, the drawing will have a copy exported as .dxf with same name and location as .idw.
Hope it helps someone!!
thanks!
'query user question = MessageBox.Show("is a .DXF Export Required", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question) 'set condition based on answer If question = vbYes Then ' Get the DXF translator Add-In. path_and_nameDXF = ThisDoc.PathAndFileName(False) Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "C:\Users\Farr\Documents\Inventor\DXF_EXPORT_INI\DXF_EXPORT.ini" oOptions.Value("Export_Acad_IniFile") = strIniFile End If oDataMedium.FileName = path_and_nameDXF & ".dxf" Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End If
code working perfect, but my first questionwould be: is it possible to run dxf for each sheet with sheet name. Second question is it possible to make dxf for each sheet but with option which sheet to be included in dxf formation
This second option would be just perfect time saver for me.
Thanks a lot
I am going to say yes, you can bring up the same type dialogue to export specific sheets to dxf, however I am not a power iLogic user. Since I marked this thread solved, you may want to create a new thread/post and reference this one to it.
I typically never use multiple sheets, forget why exactly, but I find it much easier to just adjust the size of sheet if i need more room. Also any logic used becomes more difficult to write for this reason as well.
I took the code from this thread and customized it a little (to our paths, etc.) and came up with a few issues:
The file name ends up being PartNumberPartNumber.dxf (using the actual part number). If I change the line
to
oDataMedium.FileName = SaveName & ".dxf"
it cries at me. Where is it getting the part number twice?
Also, let's say I have a 2-sheet drawing. It creates:
Partnumber.dxf
Partnumber_SHEET_1.dxf
Partnumber_SHEET_2.dxf
When I do a manual Save Copy As>DXF, it creates the two "SHEET" files, but not the first one. That's the behavior I'd like to see.
Also, this doesn't happen on a single sheet drawing, but if the files already exist, it brings up a dialogue EVERY TIME to overwrite existing files. How can I force it to overwrite with no prompt?
' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Sets directory for file save Dim DXFDirectory As String DXFDirectory = strFolder ' Sets save name as iProperties value Dim SaveName As String SaveName = iProperties.Value("Project", "Part Number") ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "\\server\Company Engineering Documents\Inventor 2013 Files\Save Templates\DXF Export.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the destination file name oDataMedium.FileName = ThisDoc.PathAndFileName(False) oDataMedium.FileName = DXFDirectory & SaveName & ".dxf" 'Publish document. DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with i = MessageBox.Show("Preview the DXF file?", "DXF Preview",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
(Never mind the "strFolder" variable. I set it above the code.)
'This is good rule change for your purpose path and folder
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Define the drawing
Dim oDrawing As DrawingDocument
oDrawing = ThisDoc.Document
Dim oSheet As Sheet
Dim lPos As Long
Dim rPos As Long
Dim sLen As Long
Dim sSheetName As String
Dim sSheetNumber As Integer
'step through each drawing sheet
Dim Response As MsgboxResult
For Each oSheet In oDrawing.Sheets
Response = MsgBox("Yes = Save or No = Continue to next Sheet?", MsgBoxStyle.YesNo, "Question")
If Response = MsgBoxResult.Yes Then
'find the seperator in the sheet name:number
lPos = InStr(oSheet.Name, ":")
'find the number of characters in the sheet name
sLen = Len(oSheet.Name)
'find the sheet name
sSheetName = Left(oSheet.Name, lPos - 1)
'find the sheet number
sSheetNumber = Right(oSheet.Name, sLen - lPos)
'get DXF target folder path
oFolder = "C:\Test Folder"
'Set the DXF target file name
oDataMedium.FileName = oFolder & "\" & " " & sSheetName & " " & sSheetNumber & ".dxf"
MessageBox.Show("DXF SAVED TO: " & oDataMedium.FileName, "DXF Saved", MessageBoxButtons.OK)
'Publish document
oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End If
Next
I was able to get the filename working correctly. Now my only issue is that is is NOT automatically overwriting existing files. Everything I've ready said the SaveCopyAs function should overwrite without prompting. Any way to force the overwrite from my code?
My problem with overwriting doesn't exist when there is only a single sheet. The problem is when there are 2 or more sheets. Inventor automatically (somehow, somewhere) appends the "_SHEET_X" to the end of each sheet when creating the DXFs. That's fine for new files but it apparently can't overwrite those without my input. Is there a way to either force that overwrite OR delete the files (could be x number of sheets) right before the .SaveCopyAs() function?
Here's what I ended up with and it works perfectly:
'query user question = MessageBox.Show("is a .DXF Export Required?" & vbNewLine & "WARNING: This operation will overwrite existing DXF files!", "Export to DXF",MessageBoxButtons.YesNo,MessageBoxIcon.Question) 'set condition based on answer If question = vbYes Then 'Bunch of IF statements here to set strFolder to the path I want the particular DXF saved in, based off the name of the drawing file ' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Sets directory for file save Dim DXFDirectory As String DXFDirectory = strFolder ' Sets save name as iProperties value Dim SaveName As String SaveName = iProperties.Value("Project", "Part Number") ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "\\server\Company Engineering Documents\Inventor 2013 Files\Save Templates\DXF Export.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the destination file name oDataMedium.FileName = ThisDoc.PathAndFileName(False) oDataMedium.FileName = DXFDirectory & SaveName & ".dxf" If ThisDoc.Document.Sheets.Count > 1 Then For sheet_count = 1 To ThisDoc.Document.Sheets.Count If Len(Dir(DXFDirectory & SaveName & "_SHEET_" & sheet_count & ".dxf")) <> 0 Then Kill(DXFDirectory & SaveName & "_SHEET_" & sheet_count & ".dxf") Else If Len(Dir(DXFDirectory & SaveName & ".dxf")) <> 0 Then Kill(DXFDirectory & SaveName & ".dxf") End If Next sheet_count End If 'Publish document. DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Launch the dxf file in whatever application Windows is set to open this document type with 'i = MessageBox.Show("Preview the DXF file? " & SaveName & " " & ThisDoc.Document.Sheets.Count, "DXF Preview",MessageBoxButtons.YesNo,MessageBoxIcon.Question) 'If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName) End If
When you run a rule I have some error messages.
Rule Compile Errors in Eksport DXF, in eksport DXF.idw
Error on Line 3 : Element "Questi" is not a member of the element
„System.Windows.Forms.MessageBoxIcon”.
Error on Line 3 : Expected comma character ")" and follow the correct expression
Error on Line 19 : Expected end of statement.
Error on Line 23 : Expected end of statement.
How to solve these problems
Best regards,
KSwietochowski
The code has been completely copied from your post above.
'query user
End If
End If
Next sheet_count
End If
'Publish document.
End If
Best regards,
KSwietochowski
Those errors are being flagged up because some unicode characters have been added when you use windows copy and paste command.
If you copy the code from the forum into notepad, and then copy it from notepad into your new rule, you will find that these errors should not be flagged up. Hope this helps
