iLogic rule running with old version of parameters
4 REPLIES 4
waynehelley
332 Views, 4 Replies
Hi all,
I have an iLogic rule which changes the value of the parameter and then triggers another rule to be run. It simply looks like this...
Parameter="Value"
iLogicVb.RunRule("MyRule")
The problem is that there are functions in the rule which are dependant on the Value of the parameter and at present, the rule seems to run with the old value of the parameter.  Is there anyway to fix this such as adding an update between the two lines of code???...
Parameter="Value"
Update
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Tags (1)
4 REPLIES 4
If parameter = "value" Then
Else 'do nothing
End If
Would that not work?
I just tried having my parameter at a random value which was '2'
Ran the following...
Coordinate_Place=1
If Coordinate_Place=1
iLogicVb.RunRule("Coordinate Place")
Else
End If
and the rule still ran with the parameter at a Value of 2  Smiley Frustrated
I just noticed there is a function 'RunRule (with map)' which can pass an argument from one rule to another.  Maybe this is what I need to use??
Wayne Helley
Visual Studio 2022
waynehelley
in reply to: waynehelley
Solved it...
If you alter the parameter using the format...
parameter("d0") = 1.2
It happens dynamically and the parameter is altered immediately
Wayne Helley
Visual Studio 2022
LukeDavenport
Hi Wayne,
Alternatively, you can use this line to output (update) the parameters at any point in a rule I believe
Luke
RuleParametersOutput()
