I have an ilogic rule that save drawing to pdf + dxf with revision number. I have used in 2014 and it works fine.
But when I try use in Inventor 2015, I got error.
I have attached the code.
Does any one have a solution so it works in Inventor 2015?
I would look into this part of your code. Maybe setting it to the 2015 version of this file will fix it.
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "C:\ProgramData\Autodesk\Airec\dxf2004 inventor 2014 MODEL.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If
