Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic problem
22 REPLIES 22
Message 1 of 23
stannm
1223 Views, 22 Replies
iLogic problem
I'm trying to create an iLogic rule which opens every drawing of every part in a assembly and then launches my rule to create a PDF and then closes the document one by one. I thought i'd be as simple as this but apperently I'm wrong.
With this code it only opens the drawing of the assembly and then closes it and then does that again.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
iLogicVb.RunExternalRule("Overige - open drawing")
iLogicVb.RunExternalRule("Export - PDF in assembly")
ThisApplication.ActiveDocument.Close(True)
Next
Can anyone help me?
Thanks!
Stan
22 REPLIES 22
Message 21 of 23
rossano_praderi
Hi Itjelta, yes it is.
Can you post your code?
I think is better if you open a new thread.
And if you don't like to publish your code, you can send me a private message with your full/partial code (of course, if you trust me).
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Message 22 of 23
in reply to: rossano_praderi
I have created a new thread:
http://forums.autodesk.com/t5/inventor-customization/help-with-ilogic-code/td-p/5424846
Thank you for reply 🙂
Message 23 of 23
rossano_praderi
in reply to: stannm
What?
Inviato da Samsung Mobile
