Hello All,
I created an iLogic rule which at the start of it invokes the Pick command within Inventor, here is what I have so far
This function works great for Parts placed within an Assembly.
The problem I have is when I have to Pick a part that is within a placed Assembly inside the Assembly I'm working in, therefore the kAssemblyOccurrenceFilter only selects the Assembly as a whole instead of the wanted part.
Is there any way I can include in the code to pick these parts within an Assembly?
Many thanks in advance any help would be much appreciated.
Kind Regards
Tim
Solved by matt_jlt. Go to Solution.
Try this
ThisApplication.CommandManager.Pick(kAssemblyLeafOccurrenceFilter,"Select Beam")
Regards, Matt.
Cheers Matt,
The kAssemblyLeafOccurrenceFilter did the trick, I knew it would be something easy just couldn't find which member it was.
Working code below
Many thanks for the help
Regards
Tim
