Hi
I want to use Ilogic to construct a code part name.
My question is perform a code of about 12 characters. For example the parameter "Lenght" is 600mm but in the expressione result It must be "000000000600" (a string of 12 characters)
Thank you in advance
Fabio
I'm kinda bored waiting for a reply to my own thread, hence spamming what might not be replies to peoples questions, anyway:
Private Sub TestFormat() Dim length As Integer length = 600 Dim code As String code = Format(600, "000000000000") End Sub
Yes it work so fine but if my "lengt" is not a number.
For ex: "A600" and i wont to convert it in "00000000A600"
Regards
Fabio
