Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Ilogic New parameter in part
11 REPLIES 11
Message 1 of 12
1415 Views, 11 Replies
This sets a multi value parameter in a part from the assembly --> MultiValue.SetListInComponent(Partname,Parametername, Value, value, value)
But how do i create a new parameter if it dosnt exist in the part? (from the assembly)
11 REPLIES 11
Message 2 of 12
http://modthemachine.typepad.com/my_weblog/2013/08/updating-parts-through-an-assembly.html
This should get you going. I searched for "add parameter in inventor ilogic"
Message 3 of 12
Vladimir.Ananyev
The following rule creates the numeric user parameter and makes it multi-value:
'reference to the document object
Dim oDoc As PartDocument = ThisDoc.Document
'reference to the user parameters collection
Dim oPars As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
'data for the multi-value list
Dim List() As String = {"11","88","77","66"}
'create parameter, current value is the first in the list
Dim oPar As UserParameter = oPars.AddByExpression("Width", List(0), "mm")
'set the multi-value list in the parameter oPar
MultiValue.List("Width") = List
oDoc.Update ' apply parameters
 cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 4 of 12
in reply to: Vladimir.Ananyev
This is as close as i get, and this generates this error
" MultiValue: Could not find a parameter named: "ParameterName" "
SyntaxEditor Code Snippet
Sub main
Dim
asmDoc As AssemblyDocument = ThisApplication.ActiveDocument Dim doc As Document For Each doc In asmDoc.AllReferencedDocuments If doc.DocumentType = kPartDocumentObject Then MakeParam(doc) End If Next End Sub
Function MakeParam(strPartname)
Dim oDoc As Document
oDoc = strPartname
MsgBox(strPartname.fullfilename)
Dim oPar As UserParameter = oPars.AddByExpression("ParameterName", List(0), "mm")
MultiValue.List("ParameterName") = List
oDoc.Update
End Function
Message 5 of 12
I think the problem is the MultiValueList command is trying to happen at the Assembly level, not at the part level.
So, I tried this
MultiValue.List(oDoc.DisplayName,"ParameterName") = List
 It kind of worked, but I'm not sure it's right (I'm trying to get to how you call a parameter of a part through an assembly, like this:
Parameter("Part1:1", "d0") = 1.2
 I am just not sure if displayname is the right thing to use here.
Vladimir, can you weigh in on that?
Message 6 of 12
Looks like it works if i use
MultiValue.SetListInComponent(oDoc.DisplayName,"ParameterName","Value","Value")
Message 7 of 12
Vladimir.Ananyev
MultiValue.SetListInComponent function works fine with components’ names.
But I get error if try to use this function with the Inventor.Document argument.
The following VB-version of  iLogic rule works with documents.  It adds the multi-value
parameter “AAA” to all referenced part documents ignoring the assembly hierarchy.
Sub Main
	'active assembly
	Dim asmDoc As AssemblyDocument = ThisDoc.Document   'ThisApplication.ActiveDocument
	'iterate the referenced documents
    For Each doc As Inventor.Document In asmDoc.AllReferencedDocuments
		'add the multi-value parameter to every part document
        If doc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            AddMultiValueParameter(doc)
    Next
	asmDoc.update
	Beep
End Sub
Sub AddMultiValueParameter(ByVal oDoc As PartDocument)
    Dim ParName As String = "AAA"  'Parameter Name
    Dim oList() As String = {"11", "88", "77", "66"}
    Dim oPar As UserParameter = Nothing
    Try
        oPar = oPars.Item(ParName)
        oPar.Delete()
    Catch ex As Exception
    End Try
    'create parameter with the first value from the list
    oPar = oPars.AddByExpression(ParName, oList(0), "mm")
    'add expression list
    For i As Integer = 0 To oList.Length - 1
        oList(i) = "" & oList(i) & ""  '<-- required
    Next
    Dim oExprList As ExpressionList = oPar.ExpressionList
    Call oExprList.SetExpressionList(oList, False)
    oDoc.Update()
End Sub
 cheers,
Vladimir Ananyev
Message 8 of 12
Thank you!!
I have stumbled on another little problem when adding a value in the multi value parameter.
This creates the parameter value  in the part but when i rightclick on the Parameter (Manage/Parameters) row and select
edit multi-value list the value dosnt show.
And i am trying to set multiple values from a dynamic array but i dont get it to work.
Any ideas?
Dim invPart As Inventor.PartDocument
Dim oCompOcc As Inventor.ComponentOccurrence
    oCompOcc = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.ItemByName("PartName")
    invPart = oCompOcc.Definition.Document
    InvParam = invPart.ComponentDefinition.Parameters.Item("ParameterName")
    InvParam.Value = "TestValue"
Message 9 of 12
Vladimir.Ananyev
You need to update the part document in order to apply parameter changes.
invPart.Update()
Hope it helps.
Vladimir Ananyev
Message 10 of 12
I forgot to copy that line, and no it dosnt work even when updated
Message 11 of 12
This is how to set a dynamic array to multi value parameter, if anyone ever need it.
For i = 0 to 5
redim preserve strArr(i)
strArr(i) = "What ever "& i
next
setParamValues
(oOccurrence.Name, "ParameterName", strArr) Public Function setParamValues(strPartName As String, strParaName As String, strValues() As String) MultiValue.SetListInComponent(strPartName,strParaName, strValues) End Function
Message 12 of 12
awatt
Did you figure this one out?  I think I'm getting the same thing.
