Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic: multiple rules, one part
1 REPLY 1
327 Views, 1 Reply
So, the component circled below is the same part on 2 different rules, they are both suppress/unsupress features.  One is true and one is false.
Component circled in red above and below:
I need to somehow put an order to these rules because if one is true the other may not be, as seen.  If ANY RULE RESULTS IN FALSE,  the part needs to be suppressed for my assembly.  Currently it seems the False statment is being overwritten with the true and the part(feature) remains unsuppressed.
Anyone know if there is an order to the rules when they are run or how to solve this problem?
1 REPLY 1
RodrigoEiras
Good afternoon,
I would say there cannot be two conditions being true at the same time that cause a part to be suppressed and unsuppressed at the same time. So the problem is in the concept itself, not in the order the rules are being run.
It seems one condition should be for example inside the other, so in case both are true you can decide what the suppression state of the part has to be.
If LHORR=0 Then
   If SENTTRANS=1 Then
   Else
   End if
Else
End If
I hope this helps.
Best regards
