Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Ilogic Member not found issue
6 REPLIES 6
gazadder
1181 Views, 6 Replies
I am having an issue with Inventor 2014 that I did not have with 2012 in relation to using ilogic to export sheet metal dxf parts from an Ilogic configured assembly.
Specifically the issue I am having is an intermittent error where the code cannot find a specific part and throws up the below message.
Error in rule: DXF, in document: IMPELLER.iam
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
The steps leading to this are:-
1:            Configuring the model using Ilogic to supress and un-suppressed required parts.
2:            Once configured I fire the Ilogic rule to run the below code which looks through un-supressed sheet metal parts based on an Iproperty value and exports the flat pattern as a dxf file.
3:            Occasionally (sometimes after several configuration changes) the dxf export rule will error stating the Member Not found Error.
The configurations are just swapping between 2 states so when an error finally occurs it is simply erroring on a configuration where it previously didn’t.
The simplest way to overcome this error seems to be saving the model assembly, close the assembly, re-open the assembly and re-run the dxf export rule.
The code as below it seems to be able to write a Part Number to the iproperties but then cannot find it to export the sheet metal.
Can anyone shed any light on why this may be? I have spent literally many days trying to diagnose the issue and find a consistent error pattern with no success.
DXF_LOC = ThisDoc.Path&"\IMPELLER_DXF\"
part_no = 1
DimasmDocAsAssemblyDocument
asmDoc = ThisApplication.ActiveDocument
DimasmDefAsAssemblyComponentDefinition
asmDef = asmDoc.ComponentDefinition
DimoCompAsInventor.ComponentOccurrence
ForEachoDocInThisApplication.ActiveDocument.AllReferencedDocuments
   IfoDoc.DocumentType = kPartDocumentObjectThen
   DimoFilenameAsString = IO.Path.GetFileName(oDoc.displayname)
   oDocName = oDoc.Displayname
   DimoIVDesignInfoAsPropertySet
   oIVDesignInfo = oDoc.PropertySets.Item("Design Tracking Properties")
   DimoIVDocSumInfoAsPropertySet
   oIVDocSumInfo = oDoc.PropertySets.Item("Inventor Document Summary Information")
   DimoIVSumInfoAsPropertySet
   oIVSumInfo = oDoc.PropertySets.Item("Inventor Summary Information")
   DimoIVCustomSetAsPropertySet
   oIVCustomSet = oDoc.PropertySets.Item("Inventor User Defined Properties")
       IfoIVSumInfo.item("Keywords").Value = "WIBBLE"Then
       oIVSumInfo.item("Title").Value = oDocName
       oIVDesignInfo.item("Part Number").Value = JOB_NUMBER&"I"&part_no
       oIVDesignInfo.item("Stock Number").Value = " "
       DimoCompDefAsComponentDefinition
       oCompDef = oDoc.ComponentDefinition
           IfoCompDef.HasFlatPattern = False Then
           oCompDef.Unfold
           oDoc.Save
           oDoc.Close
           EndIf
       DimsOutAsString
       sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_ROLL_TANGENT;IV_ARC_CENTERS"
       DimsFnameAsString
       sFname = DXF_LOC&iProperties.Value(oDocName ,"Project", "Part Number")&".dxf"
       oCompDef.DataIO.WriteDataToFile(sOut, sFname)
       part_no = part_no+ 1
       Else
       EndIf
   EndIf
Next
6 REPLIES 6
rossano_praderi
in reply to: gazadder
the "HasFlatPattern" property is valid only for the "SheetMetalComponentDefinition" and is not within a "PartDefinition" (tested on Inv.2013).
This is not your solution, but an useful information.
This is your cleaned-up code, please next time use this button  to insert your code.
DXF_LOC = ThisDoc.Path & "\IMPELLER_DXF\"
part_no = 1
Dim asmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim asmDef As AssemblyComponentDefinition = asmDoc.ComponentDefinition
For Each oDoc In asmDoc.AllReferencedDocuments
   If oDoc.DocumentType = kPartDocumentObject Then
	Dim oIVDesignInfo As PropertySet = oDoc.PropertySets.Item("Design Tracking Properties")
	Dim oIVDocSumInfo As PropertySet = oDoc.PropertySets.Item("Inventor Document Summary Information")
	Dim oIVSumInfo As PropertySet = oDoc.PropertySets.Item("Inventor Summary Information")
	Dim oIVCustomSet As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
		If oIVSumInfo.item("Keywords").Value = "WIBBLE" Then
			oIVDesignInfo.item("Part Number").Value = JOB_NUMBER & "I" & part_no
			Dim oCompDef As ComponentDefinition = oDoc.ComponentDefinition
			If oCompDef.HasFlatPattern = False Then
				oCompDef.Unfold
				oDoc.Save
				oDoc.Close
			Dim sOut As String
			Dim sFname As String
			sFname = DXF_LOC & iProperties.Value(oDocName ,"Project", "Part Number") & ".dxf"
			part_no = part_no + 1
Next
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
gazadder
in reply to: rossano_praderi
Thanks for the heads up.
I have a feeling my issue has something to do with this:-
http://forums.autodesk.com/t5/inventor-general-discussion/use-ilogic-to-set-the-size-and-length-of-a...
Do you know what the error would be in my rule and what it should be?
rossano_praderi
in my first post you will find one possible error in your code.
If you like, I can investigate on it but I need the file/files (.asm, .ipt, etc.) which cause the error.
I have only the release 2013 & 2015 of Inventor.
Bregs
Rossano Praderi
gazadder
Hi Rossano,
I have actually replaced the old code with your new neater one but I still get the error.
I could attached the assembly but the problem is that most times it runs fine with no error so it may not error for you.
rossano_praderi
Hi Gazadder, as i wrote, my code is not your solution.
I'm sure you will find someone with more experience and more time to dedicate at your issue (as wrote, I don't have the release 2014).
Bregs
Rossano Praderi
rschader
I get these Member not found errors every so often, when I did not change anything at all. Found out that if I quit Inventor and restart it, the ilogic rule that threw the error works just fine.
