ilogic is calculating tan/sin/cos/aTan/aCos/aSin incorrectly. I dont know where to start to fix the problem
e.g.
MessageBox.Show(Atan(35))
Answer = 0.4738... when it should be 0.7002....
Any ideas anyone?
Solved by jdkriek. Go to Solution.
MsgBox(Atan(35)) gives the result 1.54223266895614 rad.
craigzcool wrote:MessageBox.Show(Atan(35))Answer = 0.4738... when it should be 0.7002....
Any ideas anyone?
I think you are looking for Tan and results in degrees
Tan(35) results in 0.4738 Radians (which is what you are seeing)
Convert Radians to Degrees and you will see 0.7002 Degrees
Did Jonathan answer your question?
If so could you please set it as an accepted solution?
Thank you,
Sorry, i didnt get notified through email about the 1st responce. Yes that answers my question perfectly Thanks a lot! 🙂
