Hi InventorWizardz,
I have a problem with the folowing script:
Ivolume = iProperties.Volume/1000 '(in cm^3)GoExcel.CellValue("3rd Party:Embedding 2", "Blad1", "A2") = Ivolume
Parameter("HoogteVolumePercent") = 1
i = 1
If Parameter("HoogteVolumePercent") < 100 Then
While (Parameter("HoogteVolumePercent") < 100)
GoExcel.CellValue("3rd Party:Embedding 2", "Blad1", "C"&i) = Ivolume
i = i + 1
If i = 100 Then
Exit While
End While
iLogicVb.UpdateWhenDone = True
The purpose is to export the value of Ivolume at a certain percentage to an embedded Excel. But the when running this rule every cell has the same value.
I think Ilogic is writing the value after the completion of the rule. But I can't figue it out to get it to work.
In Attachements you can find a screenshot and the part (made in IV2013).
Hope someone can help
The problem you have is that the Parameter is not changing the part and updating it while runing the rule. When you begin your rule with:
Parameter.UpdateAfterChange = True
the parameter is updated after a change.
Rob.
Hi Rob,
Before I posted my question, I also posted on the Autodesk General Discussions forum. My mistake 😉
Andrewiv rewrote the code, and used another solution. He declares the property Ivolume again.
This solution works perfect for me.
Thanks for your suggestion !!
Greeting Dennis
http://forums.autodesk.com/t5/Inventor-General-Discussion/Ilogic-loop-to-excell/td-p/5210879
Ivolume = iProperties.Volume/1000 '(in cm^3) GoExcel.CellValue("3rd Party:Embedding 2", "Blad1", "A2") = Ivolume i = 1 If Parameter("HoogteVolumePercent") < 100 Then While (Parameter("HoogteVolumePercent") < 100) Parameter("HoogteVolumePercent") = i InventorVb.DocumentUpdate() Ivolume = iProperties.Volume/1000 '(in cm^3) GoExcel.CellValue("3rd Party:Embedding 2", "Blad1", "C"&i) = Ivolume i = i + 1 If i = 100 Then Exit While End If End While End If iLogicVb.UpdateWhenDone = True
Hi Dennis,
I'm glad that you solved it, please flag as solved as well.
Philippe.
