Solved by ceflamarion. Go to Solution.
Hi there,
Happy New Year.
One thing that seems to work is getting an up-to-date value using Parameter("MODO")
'-------------------------------------------------------------------------- iLogicForm.Show("FLAMA-GEARS", FormMode.Modal) ' Get the latest value of MODO MODO = Parameter("MODO") MsgBox(MODO) If MODO = "D e i" Then iLogicForm.Show("D e i", FormMode.Modal) End If If MODO = "Z1 e Z2" Then iLogicForm.Show("Z1 e Z2", FormMode.Modal) End If '----------------------------------------------------------------------------
Cheers,
