Inventor Customization
Valued Mentor
stephengibson76
Message 1 of 6 (503 Views)
ilogic, insert sketched symbol from another idw
503 Views, 5 Replies
06-21-2011 07:33 AM
I dont want to bloat my template idw with a load of sketched symbols.
What I would like is an ilogic rule that I can pull up a form, select a sketched symbol from a list, inventor will then automatically open another idw containing all of the symbols, then copy the selected and paste into my current idw, then close the sketched symbol idw.
effectivly what I would like to do is the same as using wblocks in autocad
Stephen Gibson
View stephen gibson's profile on LinkedIn
matt_jlt
Message 2 of 6 (499 Views)
Re: ilogic, insert sketched symbol from another idw
06-21-2011 07:09 PM in reply to: stephengibson76
You would have to use VB with the iLogic as iLogic code on it's own has limited capabilities.
Is there any reason it has to be iLogic? This would be much easier as a seperate VBA Macro / VB.Net Addin as you could just have it on the toolbar. Just a Thought :smileyhappy:
Regards, Matt.
Valued Mentor
stephengibson76
Message 3 of 6 (491 Views)
06-23-2011 12:44 AM in reply to: matt_jlt
no reason it has to be ilogic, other than I can probably work out whats going on.  can anyone do me some VB that will do the job?
Stephen Gibson
Employee
RobertStein
Message 4 of 6 (480 Views)
06-23-2011 04:51 AM in reply to: stephengibson76
Here is some sample code a friend wrote for me. Copy and paste it into a VBA macro and tweak whatever you need.
Function CopyFrom(otherDrawingName As String, symbolName As String, thisDrawingDoc As DrawingDocument) As SketchedSymbolDefinition
On Error GoTo CannotOpen
Dim otherDrawing As DrawingDocument
Set otherDrawing = ThisApplication.Documents.Open(otherDrawingName, False)
Set CopyFrom = Nothing
Dim symbolDef As SketchedSymbolDefinition
For Each symbolDef In otherDrawing.SketchedSymbolDefinitions
   If (StrComp(symbolDef.Name, symbolName, vbTextCompare) = 0) Then
     Set CopyFrom = symbolDef.CopyTo(thisDrawingDoc, ReplaceExisting:=True)
   End If
Next
otherDrawing.ReleaseReference
If (CopyFrom Is Nothing) Then
   Call MsgBox("Cannot find a sketched symbol named " & symbolName & " in the file " & otherDrawingName, vbOKOnly, "Sketched Symbol Copy")
End If
Exit Function
CannotOpen:
Call MsgBox("Cannot find (or open) a file named: " & otherDrawingName)
End Function
Sub Test()
  Dim sourceName As String
  sourceName = "C:\inv-dev2\parts2011g\SketchedSymbolCopy\SymbolSourceA.idw"
  Dim symbolName As String
  symbolName = "Dowel"
  Set symbolDef = CopyFrom(sourceName, symbolName, ThisApplication.ActiveDocument)
   Dim oSheet As Sheet
   Set oSheet = ThisApplication.ActiveDocument.ActiveSheet
  ' Test adding it to the drawing:
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oSketchedSymbol As SketchedSymbol
    Set oSketchedSymbol = oSheet.SketchedSymbols.Add(symbolDef, oTG.CreatePoint2d(5, 5), 0#, 0.75)
End Sub
Rob Stein
Real Software Solutions
robert.stein@yourrealsoftwaresolutions.com
Robert Stein
Technical Consultant
Global Services, Amer Project Delivery Team
Valued Mentor
stephengibson76
Message 5 of 6 (475 Views)
06-23-2011 06:44 AM in reply to: RobertStein
thankyou, I will give it a try next week
Stephen Gibson
Valued Mentor
stephengibson76
Message 6 of 6 (453 Views)
07-06-2011 01:43 AM in reply to: stephengibson76
Thanks, I got it working to bring in a specific symbol.  What I would like is a list of symbols that I can choose which one to bring into my idw
Stephen Gibson
