Hi All,
I have the following piece of iLogic cobbled together from various sources:
Dim doc as Document doc = ThisApplication.ActiveDocument 'Verify the current document has been saved. If doc.FullFileName = "" Then MessageBox.Show("This document must be saved first.") Exit Sub End If Dim selectedfile As String = String.Empty Dim oFileDlg As inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg) oFileDlg.Filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt" oFileDlg.InitialDirectory = oOrigRefName oFileDlg.CancelError = True oFileDlg.MultiSelectEnabled = True On Error Resume Next oFileDlg.ShowOpen() If Err.Number <> 0 Then Return ElseIf oFileDlg.FileName <> "" Then selectedfile = oFileDlg.FileName End If MessageBox.Show("You selected: " & selectedfile , "iLogic") Dim oleReference As ReferencedOLEFileDescriptor If selectedfile.Contains("|") Then ' we have multiple files selected. Dim file As String() = selectedfile.Split("|") For Each s as String in file MessageBox.Show("You selected: " & s , "iLogic") oleReference = doc.ReferencedOLEFileDescriptors.Add(s,kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = false oleReference.DisplayName = Mid$(s, InStrRev(s, "\") + 1) Next Else oleReference = doc.ReferencedOLEFileDescriptors.Add(selectedFile,kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = false oleReference.DisplayName = Mid$(selectedFile, InStrRev(selectedFile, "\") + 1) End If
It works fine except that the resultant "3rd Party" folder contains icons with this image:
Instead of the image created when you manually click the "Insert Object" button on the Manage Ribbon -> Insert tab:
Am I missing something which means that iLogic-inserted olereferences aren't treated the same as manually input ones?
Also, when I do this manually, the files are added to Vault Pro 2014 as "children" of whichever file I have run the iLogic within.
Thanks in advance,
Alex.
Solved by Vladimir.Ananyev. Go to Solution.
Strange...
I just modified the same ilogic code above to work in vba and lo, it works as expected.
Here's my original source modified to be vba-friendly:
Public Sub addolereferences() Dim doc As Document Set doc = ThisApplication.ActiveDocument 'Verify the current document has been saved. If doc.FullFileName = "" Then MessageBox.Show ("This document must be saved first.") Exit Sub End If Dim selectedfile As String 'Set selectedfile = "" Dim oFileDlg As Inventor.FileDialog Set oFileDlg = Nothing Call ThisApplication.CreateFileDialog(oFileDlg) oFileDlg.filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt" oFileDlg.InitialDirectory = oOrigRefName oFileDlg.CancelError = True oFileDlg.MultiSelectEnabled = True On Error Resume Next Call oFileDlg.ShowOpen If Err.Number <> 0 Then Return ElseIf oFileDlg.FileName <> "" Then selectedfile = oFileDlg.FileName End If 'MessageBox.Show("You selected: " & selectedfile , "iLogic") Dim oleReference As ReferencedOLEFileDescriptor If InStr(1, selectedfile, "|") > 0 Then 'If selectedfile.Contains("|") Then ' we have multiple files selected. Dim file() As String file() = Split(selectedfile, "|") For Each s In file 'MessageBox.Show("You selected: " & s , "iLogic") oleReference = doc.ReferencedOLEFileDescriptors.Add(s, kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = True oleReference.DisplayName = Mid$(s, InStrRev(s, "\") + 1) Next Else oleReference = doc.ReferencedOLEFileDescriptors.Add(selectedfile, kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = False oleReference.DisplayName = Mid$(selectedfile, InStrRev(selectedfile, "\") + 1) End If End Sub
the one functional change (which makes no difference in iLogic!) is
instead of the previous:
Is this a bug or "as intended"?
I get the equivalent results in the iLogic and VBA versions of your rule.
To work correctly in VBA it is necessary to add SET to the both code lines:
Set oleReference = doc.ReferencedOLEFileDescriptors.Add(selectedfile, kOLEDocumentLinkObject)
In my test I added a bitmap image to the drawing sheet. Both properties
oleReference.BrowserVisible = True / False and oleReference.Visible = True / False
work as expected.
Thank Vladimir, I had forgotten to "Set" the alternating oleReference objects.
That doesn't answer the question as to why code that is functionally identical works when used via vba but not in iLogic?
Strange, I don't see any difference between iLogic and VBA versions.
I used Inventor Prof 2015 SP1 Update 1 (Build 203).
What is your configuration?
Hi Vladimir,
I am using Inventor 2014 Pro SP2 Update 3 (Build 246)
Alex.
Hi Alex,
It looks like the problem with icons in case of iLogic rule has surprisingly simple solution suggested by Mike Deck.
In VB.NET (and thus iLogic), Enum members (constants) must be qualified with their type name.
To find the type name, search for the enum (in Inventor, almost all enum constants start with the letter k)
in the Inventor API help. Searching for kOLEDocumentLinkObject, you will find the OLEDocumentTypeEnum page.
To help detect these constants in code, you can add the statement
Option Explicit On
at the top of the rule. This will require that all variables be declared explicitly.
So I've added "Option Explicit On" in the first line, and then added OLEDocumentTypeEnum qualifier to both constants kOLEDocumentLinkObject.
Other minor changes do not influence to the icons and were added to simplify code a little.
Here is my final version. This code works both in Inventor 2014 and 2015.
Option Explicit On 'current document Dim doc as Inventor.Document = ThisDoc.Document 'Verify the current document has been saved. If doc.FullFileName = "" Then MessageBox.Show("This document must be saved first.") Exit Sub End If 'default folder Dim FolderName As String = Left$(doc.FullFileName, InStrRev(doc.FullFileName, "\") ) Dim selectedfile As String = String.Empty Dim oFileDlg As inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg) 'oFileDlg.Filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt" oFileDlg.InitialDirectory = FolderName oFileDlg.CancelError = True oFileDlg.MultiSelectEnabled = True Try oFileDlg.ShowOpen() selectedfile = oFileDlg.FileName Catch Return 'operation was cancelled by the user End Try Dim oleReference As ReferencedOLEFileDescriptor If selectedfile.Contains("|") Then ' we have multiple files selected. Dim file As String() = selectedfile.Split("|") For Each s as String in file oleReference = doc.ReferencedOLEFileDescriptors _ .Add(s, OLEDocumentTypeEnum.kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = False oleReference.DisplayName = Mid$(s, InStrRev(s, "\") + 1) Next Else oleReference = doc.ReferencedOLEFileDescriptors _ .Add(selectedFile,OLEDocumentTypeEnum.kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = False oleReference.DisplayName = Mid$(selectedFile, InStrRev(selectedFile, "\") + 1) End If
The following figures illustrate the difference in results:
cheers,
Thanks Vladimir (And Mike) for the solution.
Hi.
I have similar problem.
I make an PDF and DWG drawing of my idw with I logic, that works fine, but then I need to add it manually by Insert object button and so on to get it as a "3rd Party" files in the idw.
What would be the easiest code to add the files with ilogic?
@Anonymous - not sure why I hadn't seen this reply before now, so apologies for that! For anyone else interested here is my completed Rule:
Option Explicit On Sub Main() 'current document Dim doc as Inventor.Document = ThisDoc.Document 'Verify the current document has been saved. If doc.FullFileName = "" Then MessageBox.Show("This document must be saved first.") Exit Sub End If 'default folder Dim FolderName As String = Left$(doc.FullFileName, InStrRev(doc.FullFileName, "\") ) Dim selectedfile As String = String.Empty Dim oFileDlg As inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg) oFileDlg.Filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt|Inventor iFeatures (*.ide)|*.ide|Other files (*.*)|*.*" oFileDlg.InitialDirectory = FolderName oFileDlg.CancelError = True oFileDlg.MultiSelectEnabled = True Try oFileDlg.ShowOpen() selectedfile = oFileDlg.FileName Catch Return 'operation was cancelled by the user End Try AddReferences(doc, selectedfile) End Sub Public Sub AddReferences(ByVal odoc as Inventor.Document, ByVal selectedfile As String) Dim oleReference As ReferencedOLEFileDescriptor If selectedfile.Contains("|") Then ' we have multiple files selected. Dim file As String() = selectedfile.Split("|") For Each s as String in file oleReference = odoc.ReferencedOLEFileDescriptors _ .Add(s, OLEDocumentTypeEnum.kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = False oleReference.DisplayName = Mid$(s, InStrRev(s, "\") + 1) Next Else oleReference = odoc.ReferencedOLEFileDescriptors _ .Add(selectedFile,OLEDocumentTypeEnum.kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = False oleReference.DisplayName = Mid$(selectedFile, InStrRev(selectedFile, "\") + 1) End If End Sub
Its an older post but maybe I get an answer here.
I used the rule above to attache pdf/stp/dxf exports to the file. It works fine.
My problem is the following.
When I change something on the drawing i will export the files again and it will automaticlly update the export-files always the same location. With my current rule it always adds new links in the 3rd party section. Can i add a command to the rule which is looking if these Reference is already existing, if so then just cancel and don't add new links?
Option Explicit On Option Explicit On Sub Main() 'current document Dim doc As Inventor.Document = ThisDoc.Document 'Verify the current document has been saved. If doc.FullFileName = "" Then MessageBox.Show("This document must be saved first.") Exit Sub End If 'default folder Dim FolderName As String = Left$(doc.FullFileName, InStrRev(doc.FullFileName, "\") ) Dim selectedfile As String = String.Empty Dim selectedfile2 As String = String.Empty Dim selectedfile3 As String = String.Empty Dim oFileDlg As Inventor.FileDialog = Nothing InventorVb.Application.CreateFileDialog(oFileDlg) 'oFileDlg.Filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt|Inventor iFeatures (*.ide)|*.ide|Other files (*.*)|*.*" 'oFileDlg.InitialDirectory = FolderName 'oFileDlg.CancelError = True 'oFileDlg.MultiSelectEnabled = True Try 'oFileDlg.ShowOpen() selectedfile = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & ThisDoc.FileName(False) & ".pdf" selectedfile2 = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & ThisDoc.FileName(False) & ".dxf" selectedfile3 = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & ThisDoc.FileName(False) & ".stp" Catch Return 'operation was cancelled by the user End Try AddReferences(doc, selectedfile) AddReferences2(doc, selectedfile2) AddReferences3(doc, selectedfile3) End Sub Public Sub AddReferences(ByVal odoc As Inventor.Document, ByVal selectedfile As String) Dim oleReference As ReferencedOLEFileDescriptor oleReference = odoc.ReferencedOLEFileDescriptors _ .Add(selectedfile,OLEDocumentTypeEnum.kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = False oleReference.DisplayName = Mid$(selectedfile, InStrRev(selectedfile, "\") + 1) End Sub Public Sub AddReferences2(ByVal odoc As Inventor.Document, ByVal selectedfile2 As String) Dim oleReference As ReferencedOLEFileDescriptor oleReference = odoc.ReferencedOLEFileDescriptors _ .Add(selectedfile2,OLEDocumentTypeEnum.kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = False oleReference.DisplayName = Mid$(selectedfile2, InStrRev(selectedfile2, "\") + 1) End Sub Public Sub AddReferences3(ByVal odoc As Inventor.Document, ByVal selectedfile3 As String) Dim oleReference As ReferencedOLEFileDescriptor oleReference = odoc.ReferencedOLEFileDescriptors _ .Add(selectedfile3,OLEDocumentTypeEnum.kOLEDocumentLinkObject) oleReference.BrowserVisible = True oleReference.Visible = False oleReference.DisplayName = Mid$(selectedfile3, InStrRev(selectedfile3, "\") + 1) End Sub
Hi AlexFielder.
Thanks a lot for this. I still had this problem daily or weekly but now you have solved it for me!
Me and my colleges will now use this rule. It works perfect!
Finally I found out myself how to check if the link is already existing... in case it is there it will delete it
I have now a complete function which saves PDF,DXF and STP of a drawing and attaches the "Export" files to the drawing. So when I check it into the vault all files are there...
PDF/DXF/STEP Export is not included in the code below...
Option Explicit On Sub Main() 'current document Dim doc As Inventor.Document = ThisDoc.Document Dim oleReference As ReferencedOLEFileDescriptor = Nothing Dim selectedfilePDF As String = String.Empty Dim selectedfileDXF As String = String.Empty Dim selectedfileSTP As String = String.Empty 'Verify the current document has been saved. If doc.FullFileName = "" Then MessageBox.Show("This document must be saved first.") Exit Sub End If ' Link file Try selectedfilePDF = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & "EXPORT_" & ThisDoc.FileName(False) & ".pdf" selectedfileDXF = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & "EXPORT_" & ThisDoc.FileName(False) & ".dxf" selectedfileSTP = "C:\Vault_WORK\TC_VAULT\DOCUMENTS\KS US\00_EXPORT-2D\" & "EXPORT_" & ThisDoc.FileName(False) & ".stp" Catch Return 'operation was cancelled by the user End Try AddReferencesPDF(doc, selectedfilePDF) AddReferencesDXF(doc, selectedfileDXF) AddReferencesSTP(doc, selectedfileSTP) End Sub 'PDF-Attachment Public Function AddReferencesPDF(ByVal odoc As Inventor.Document, ByVal selectedfilePDF As String) Dim doc As Inventor.Document = ThisDoc.Document Dim OLERefPDF As ReferencedOLEFileDescriptor = Nothing Dim OLERefsPDF As ReferencedOLEFileDescriptors = doc.ReferencedOLEFileDescriptors Try OLERefPDF = OLERefsPDF.ItemByName(selectedfilePDF) ' File is already attached - delete the attachment so it can be recreated... OLERefPDF.Delete() Catch ' The file is not already attached - continue... End Try Try OLERefPDF = doc.ReferencedOLEFileDescriptors.Add(selectedfilePDF, OLEDocumentTypeEnum.kOLEDocumentLinkObject) Catch MsgBox("Failed to link to the file", 64, "Export vault") Return False End Try End Function 'DXF-Attachment Public Function AddReferencesDXF(ByVal odoc As Inventor.Document, ByVal selectedfileDXF As String) Dim doc As Inventor.Document = ThisDoc.Document Dim OLERefDXF As ReferencedOLEFileDescriptor = Nothing Dim OLERefsDXF As ReferencedOLEFileDescriptors = doc.ReferencedOLEFileDescriptors Try OLERefDXF = OLERefsDXF.ItemByName(selectedfileDXF) ' File is already attached - delete the attachment so it can be recreated... OLERefDXF.Delete() Catch ' The file is not already attached - continue... End Try Try OLERefDXF = doc.ReferencedOLEFileDescriptors.Add(selectedfileDXF, OLEDocumentTypeEnum.kOLEDocumentLinkObject) Catch MsgBox("Failed to link to the file", 64, "Export vault") Return False End Try End Function 'STEP-Attachment Public Function AddReferencesSTP(ByVal odoc As Inventor.Document, ByVal selectedfileSTP As String) Dim doc As Inventor.Document = ThisDoc.Document Dim OLERefSTP As ReferencedOLEFileDescriptor = Nothing Dim OLERefsSTP As ReferencedOLEFileDescriptors = doc.ReferencedOLEFileDescriptors Try OLERefSTP = OLERefsSTP.ItemByName(selectedfileSTP) ' File is already attached - delete the attachment so it can be recreated... OLERefSTP.Delete() Catch ' The file is not already attached - continue... End Try Try OLERefSTP = doc.ReferencedOLEFileDescriptors.Add(selectedfileSTP, OLEDocumentTypeEnum.kOLEDocumentLinkObject) Catch MsgBox("Failed to link to the file", 64, "Export vault") Return False End Try End Function
I'm glad you figured out a process that works for you, but you know that those three methods are functionally and objectively identical right?
