Inventor Customization
Active Contributor
NCostelloe
Message 1 of 5 (430 Views)
Accepted Solution
iLogic in standard assembly
430 Views, 4 Replies
01-23-2012 02:01 AM
Here's the gist of what I'm trying to do...
We have a standard conveyor belt that I want to be able to quickly change the length and breadth of. I'm using a skeleton in which all the contains all the dimensions needed to make the conveyor. The assembly and parts in the assembly are driven by the parameters in the skeleton
I'm a iLogic novice but have been able to figure out a lot of things by just playing with the commands. But now I've run into a major problem.
We use Vault Workgroup and have set it up so that it does not allow duplicate file names. I want open (or import) the standaard conveyor and with iLogic
1) rename and save the assembly and all the parts (except cc parts) including the skeleton
2) the parts then need to refer to the skeleton with the new name.
Is this possible in iLogic? Any comments / suggestions would be much appreciated.
Thanks in advance
Nathan Costelloe
Inventor Ultimate 2012 64-bit
Windows 7
Intel Xeon W3670 3.2 GHz
Nvidia Quadro 4000 1750Mb
Use place ilogic component, you can find this command in your place pulldown menu in assembly file.
Ilogic automaticly creates copies of your file. If you use the filenumber scheme from workgroup, all the new filenames will be created as a unique filename. So you cann't get into trouble about filenaming.
I think i can say goodby in dutch ??
Succes
Groeten theo
Active Contributor
NCostelloe
Message 2 of 5 (412 Views)
Re: iLogic in standard assembly
01-25-2012 06:25 AM in reply to: NCostelloe
Anyone?
Nathan Costelloe
Windows 7
Valued Contributor
theo.bot
Message 3 of 5 (401 Views)
01-25-2012 07:50 PM in reply to: NCostelloe
Succes
Groeten theo
Active Contributor
NCostelloe
Message 4 of 5 (394 Views)
01-26-2012 04:32 AM in reply to: theo.bot
Theo! You nailed it, mate! Cheers!
Now to get it do want I want it to do... :smileywink:
(and you're dutch isn't bad either)
Dankjewel en groetjes!
Nathan
Nathan Costelloe
Windows 7
Active Contributor
NCostelloe
Message 5 of 5 (367 Views)
02-06-2012 05:22 AM in reply to: NCostelloe
An update... it works perfectly!  Inventor only copies the files in the folder in which the main assembly is. Leaves the CC parts alone. Sets parts to reference if they are suppressed in your new assembly so the quantites are all good. Works a treat!
Thanks again Theo for your help.
Nathan Costelloe
Windows 7
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
