Here's the gist of what I'm trying to do...
We have a standard conveyor belt that I want to be able to quickly change the length and breadth of. I'm using a skeleton in which all the contains all the dimensions needed to make the conveyor. The assembly and parts in the assembly are driven by the parameters in the skeleton
I'm a iLogic novice but have been able to figure out a lot of things by just playing with the commands. But now I've run into a major problem.
We use Vault Workgroup and have set it up so that it does not allow duplicate file names. I want open (or import) the standaard conveyor and with iLogic
1) rename and save the assembly and all the parts (except cc parts) including the skeleton
2) the parts then need to refer to the skeleton with the new name.
Is this possible in iLogic? Any comments / suggestions would be much appreciated.
Thanks in advance
Solved by theo.bot. Go to Solution.
Anyone?
Theo! You nailed it, mate! Cheers!
Now to get it do want I want it to do...
(and you're dutch isn't bad either)
Dankjewel en groetjes!
Nathan
An update... it works perfectly! Inventor only copies the files in the folder in which the main assembly is. Leaves the CC parts alone. Sets parts to reference if they are suppressed in your new assembly so the quantites are all good. Works a treat!
Thanks again Theo for your help.
