I have the following code to clean up iProperties in idw files.
If ThisDoc.Document.documenttype=12292 Then doc = ThisDrawing.ModelDocument iProperties.Value("Project", "Revision Number") = doc.PropertySets.Item(1).Item("Revision Number").Value iProperties.Value("Project", "Part Number")= "" iProperties.Value("Project", "Description")= "" iProperties.Value("Summary", "Title")="" iProperties.Value("Summary", "Subject")="" iProperties.Value("Summary", "Author")="" iProperties.Value("Project", "Project")= "" iProperties.Value("Project", "Designer")= "" iProperties.Value("Project", "Engineer")= "" iProperties.Value("Project", "Authority")= "" iProperties.Value("Project", "Cost Center")= "" iProperties.Value("Project", "Creation Time")= #1/1/1601# iProperties.Value("Status", "Status")="" iProperties.Value("Status", "Checked By")="" iProperties.Value("Status", "Checked Date")= #1/1/1601# iProperties.Value("Status", "Engr Approved By")="" iProperties.Value("Status", "Engr Date Approved")=#1/1/1601# iProperties.Value("Status", "Mfg Approved By")="" iProperties.Value("Status", "Mfg Date Approved")=#1/1/1601# End If
For some reason, when this code runs, it always trys to execute the doc=ThisDrawing.ModelDocument, regardless of whether or not the IF statment condition is true. I have no idea what is wrong here.
I am running Inventor 2012, SP2
Thank you for your help.
Solved by Curtis_Waguespack. Go to Solution.
Hi ilotey,
I think you want the second line to read:
doc = ThisDoc.ModelDocument
rather than:
This snippet seems to work for me:
iProperties.Value("Project", "Revision Number") = _
I hope this helps.
Curtis
Thanks Curtis, that seems to have worked.
But why does Inventor try to evaluate ThisDrawing.ModelDocument even though the IF condition is not satisified?
-Iqbal.
