What is it for and how do I use it?
Will it allow me to switch between different pictures for display on my iLogic form?
If so? How do I set which picture to display?
Where can I get more in depth help on this stuff?????
Solved by MjDeck. Go to Solution.
When you drag in a Picture Fodler object, it contains two Picture objects. You can add more.
- Click on each Picture object, click on the Image property and browse to a bitmap file.
- Change the Label (name) of each Picture object to something meaningful.
- Create a Text parameter (named PictureName or something similar) in your part or assembly. Make it a multi-value parameter. Set the possible values to be the same as the labels (names) of the Picture objects that you have just named.
- Add another Picture object to your form. Add it outside of the Picture folder. This will be a visible object, shown on the form.
- Click on the Picture Parameter Name property of that new Picture object. Set it to the name of your Text parameter (PictureName in this example).
Then you can use a rule to drive the value of the PictureName parameter. This will change the image in the form.
More informations by movie here :
http://wikihelp.autodesk.com/Inventor/enu/2012/Videos/ilogic_form_designer_use_pictures
Hi all,
I have a similar problem to this. Can I switch between the images by selecting difrent tabs in my form ? I want to update the image by the selected tab.
I have tried "if" or "select case" and neither one worked. as I am saying Stair_Properties = True it only makes the tab active. It doesnt indicate if it is selected, here is the code :
If Stair_Properties = True Then Image = "Image 01" End If If Railing_Properties = True Then Image = "Image 02" End If If Riser_Properties = True Then Image = "Image 03" End If 'Select Case Image 'Case Stair_Properties 'Image = "Image 01" 'Case Railing_Properties 'Image = "Image 02" 'Case Riser_Properties 'Image = "Image 03" 'End Select
Any help would be great...
There are no events to trigger the switch of a picture by clicking on a tab. What I would do is place a picture on each tab with what I way to convey.
