Hi to all,
Here I have some doubts on ilogic form.
Here my doubt is I entered If i entered COLUMN values like If i entered COLUMN 1 to 3 If i entered COLUMN:1 then i want to disable 2nd column and 3rd column values automatically, If If i entered COLUMN:2 third one is automatically hide or disable.
Is it possible in ilogic form?
Please help me.
Thanks in advance.
Thanks & Regards,
LINUS KOTTE
Solved by linuskotte. Go to Solution.
That's just an idea. You may split your complicated form into 3 simpler forms. Then you may open the Form2 or Form3 depending on the COLUMN value in the Form1. This coud be done from iLogic rule.
If I understand correctly, the answer is yes. You will need to create two boolean (True/False) parameters that is defined by your column parameter. Then use the two paramaters to control the "Enabling Parameter Name" property for the second and third column data. See my attached example. Hope that helps.
Dan
Here i have some problem giving condition in ilogic is when iam selected COLUMN:1 then 2nd column value is 0 and same way in COLUMN:2 2nd column value is user choice it's 1 or 2.
how to give condition for this?
iam try to giving this condition like this but it's not working.
If COLUMNS = 1 Then Vertical_com2 = 0 Vertical_com3 = 0 End If If COLUMNS = 2 Then Vertical_com2 = 1 Or 2 Vertical_com3 = 0 End If
here result is in 2nd column is 3
thanks & regards,
LINUS KOTTE
please solve my problem
Are the Vertical_com2 and Vertical_com3 parameters True/False parameters or are they numeric parameters?
The parameter that controls the settings in the form must be a True/False parameter. See the example that I attached before. That should help explain a few things.
Dan
Hi danvang thanks for responding my query.
Here i will explain clearly in your attachment is useful for when parameter false condition box in read only it's in true condition box in editable .
But here ur solution is true but here scenario is different when iam using false conditon 2nd box box in read only and in true condition value depends on user choice it's 1 or 2, but iam trying using if condition it's not working.
Here problem is not read only and editable problem is when iam selecting column:1 then 2nd column should be 0 and Column :2 then second column value is user choice it should be 1 or 2.
I think ur understood now if any mistakes in my english sorry please understand my problem
Thanks & regards,
LINUS KOTTE
Ok I think I understand now. You want to set values to 0 when they are not enable or in use? You are very close. You have the local already. You will just have to add those parameter values in the same rule that controls the true/false parameters. I've attached my sample with the adjustments. Is this what you are looking for?
The only thing is when Column is 2, you need to decide if the default value for Vertical_Com2 will be 1 or 2.
Dan
HI danvang your solution is ok but i want different solution like in my user interface like this .
in my UI 2nd column box is drop down box when iam select COLUMN: 2 then 2nd COLUMN value should be user choice only 1 or 2. If iam selecting COLUMN 1 then 2ND COLUMN should be only 0 , Thats why iam keeping in 2nd column combo box only 1 and 2 values and iam writing condition like this then when COLUMN 1, 2ND column automatically in 0, that's why in above UI showing 0 values but when iam clicking 2ND COLUMN combo box only 1 and 2 are activated.
If COLUMNS = 1 Then
Vertical_com2 = 0
Vertical_com3 = 0
If COLUMNS = 2 Then
Vertical_com3 = 0
Thanks & Regards,
LINUS KOTTE
Alright. One more crack at this. See the attached file. you will need to use the MaultValue.Setlist code snippet.
Thankyou very much danvang this is what iam asking.
thanks & Regards,
LINUS KOTTE
This is in regards with query of Ilogic functionality of Inventor I have an assembly file say “xyz.iam” and corresponding drawing file by name “xyz.dwg” Now I am going make dimension changes in assembly file “xyz.iam”, as we know that these changes will propagate to “xyz.dwg” as well.
My query is, whenever I make dimensional changes in “xyz.iam”, illogic have to ask me to rename or change the name of drawing sheet.
I am aware of itrigger option.
Please let me know the sample illogic code to perform the above mentioned operation
Thanking you in anticipation.
