Inventor Customization
0 Kudos
Post 1 of 4
ilogic form trigger
431 Views, 3 Replies
11-29-2012 03:18 PM
I have a ipt which is controlled via an ilogic form,this form is opened by ilogic code, which in turn is triggered when the ipt is opened.
my problem is when the part is placed within an assembly the said form is triggered and the same happens when the assembly is reopened!.... I would prefer if the form opened only when the ipt is opened or edited....
Is there a snippet of code for this? Or is it even possible?
Try the following code in the rule file that is being opened on open :
Dim CurrentDoc as PartDocument = ThisDoc.Document
If (Not (CurrentDoc Is ThisApplication.ActiveDocument)) Then Return
Valued Mentor
187 Kudos
Post 2 of 4
Re: ilogic form trigger
11-30-2012 06:25 AM in reply to: Fleagle8t
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
0 Kudos
Post 3 of 4
01-12-2013 12:24 AM in reply to: MegaJerk
Works at treat, thanks MegaJerk. :smileyhappy:
New Member
0 Kudos
Post 4 of 4
07-09-2014 07:02 AM in reply to: Fleagle8t
Hello, I came across this post and tried using the code in the solution. I still have problems at the assembly level, when I reopen the assembly all my forms will come up again. I have the event trigger set (in the iLogic part) to when the document opens the form will appear. but I would like to have it only appear once upon initial placement of the iLogic part.
