Hi
I am hoping someone could be able to help with the following
We are building parametric adjustable model running of i logic rules and parameter equations wich work great .
The problem that i am having is that parts in the model already have all their part numbers in place , now when i edit something for instance the lenght some of the parts need to change to update the model and some will stay the same as it is now a similar assembly (maybe just longer).
Now the parts that have changed still have there original part numbers wich are then incorrect as the longer part is now a new part and needs a new number , after updating the model I however have no idea wich parts changed as the models are quite complex .
My question then
Is there a way (Maybe a rule of some sort ) that will allow inventor to on save tell me wich parts changed and allow me to enter new part numbers in say a dialog box.
( No we do not run vault or any real MRP program to manage this for us )
Any help will be greatly appreciated . I have attached a simple sample parametric model to play with ...
use OnSaveDocument Event
ApplicationEvents.OnSaveDocument( DocumentObject As Document, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, HandlingCode As HandlingCodeEnum )
BeforeOrAfter Input indicating if the notification is being sent before the document is saved (kBefore), after a change is made (kAfter), or when a change has been aborted (kAbort).
'Firstly you need a class that sinks the events, for example: Option Explicit Private WithEvents oApplicationEvents As ApplicationEvents Private Sub Class_Initialize() Set oApplicationEvents = ThisApplication.ApplicationEvents End Sub Private Sub Class_Terminate() Set oApplicationEvents = Nothing End Sub Private Sub oApplicationEvents_OnSaveDocument(ByVal DocumentObject As Document, ByVal BeforeOrAfter As EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum) If (BeforeOrAfter = kBefore) Then MsgBox ("about to save " & DocumentObject.FullFileName) Else MsgBox (DocumentObject.FullFileName & " has been saved") End If End Sub 'Then you need to create an instance of this class so that 'the event is reacted to e.g. Option Explicit Dim oEventHandler As MyEventHandler Sub listenToEvents() Set oEventHandler = New MyEventHandler End Sub Sub stopListening() Set oEventHandler = Nothing End Sub
