My client has lots of ilogic parts that make the part and the drawing.
Issue is one computer out of ten has errors when he runs the ilogic parts. He had made almost 100 of the ilogic parts but yesterday he started running into ilogic errors but only on this one machine.
Why is that?
Here are the errors but remeber it only happens on this one machine. If you need to see code let me know I don't know why you would if they work on the other 9 computers and worked on this one until yesderday.
No updates were done on this computer or the others.
this don't mae sense to me..
Solved by jletcher. Go to Solution.
To add to it now this machine says he has a part open when he does not have any part open..
See attached file
More information.
After shut down restart I can change projects BUT when I try to run another ilogic part it does the errors in 1st post then locks out the project file saying a part is open.
But there is no part open.
ok I have figured it out don't know how it happened but it is fixed now.
After trying to figure it out with ilogic and other things I restarted Inventor it let me change projects I went to an older project that he made 100 plus parts in and was able to make them. So I changed back to the other project and it failed again.
I shut inventor down and did a look at the project it was failing. Come to find out the Workspace some how changed to workgroup and removed the workspace path.
I do not know how it happen because he made ilogic parts in that project before and that was what made me look into other things..
So if any on runs into this check to make sure you have a workspace path if you code tells it to save in a workspace.
path = ThisDoc.WorkspacePath()
With no workspace it errored out.
Sorry to waste your time...
To add to this it was a pack and go project file .ipj
So if you do a pack and go I suggest re-making a .ipj not use the one pack and go makes because it makes a workgroup no workspace.
I was not told that..
