We had an engineer who created a iLocic rule which is no longer in use, however we have many files that keep trying to find this rule. We get the following error:
iLogic Event-Driven Rule
RunRule: Cannot find a rule with the name: "External Part Rule".
I don't know of a way to find the many files that are looking for this rule other than opening each and every file associated with the .iam file to see if it is looking for the "External Part Rule" iLogic file.
Does anyone have any ideas as to how to resolve this issue?
Thanks in advanced for any help!
You will definitely need to load each file in Inventor at some point in order to analyze the rules code.
The iLogic API allows you to retrieve each rule contained in a file and also to access the code of the rules as string, so you could write your own parser that detects if the rule in question is invoked by any other rule.
Another suggestion would be to recreate that missing rule with a different code, so each time it is invoked you can keep track of which file has called it.
I hope it helps.
Philippe
accidently found the solution, uncheck this. This should help a bunch of people that visit this thread.
I have the same error.
I've an assembly, this assembly contains some rules to edit the assembly. The parameters are driven by a embedded excelfile. After changing the parameters and updating the assembly, I want to make dxf-file of a little sheetmetal-parts. I've a rule that runs well for creating dxf-files of sheetmetal-parts. This rule runs in the sheetmetal-parts.
I tried to trigger the rule by the eventtrigger change part geometry, it works but when updating the assembly the error appears. when clicking ok, the rule runs well.
I delete the the eventtrigger, but the error remains, this is remarkeble
So I don't know what to do, I can't find what cause the error.
Do someone know how to solve this error and how to trigger this rule in a good way.
thank you for helping
i got the same error, had some files containing a reference to an external rule that triggerd upon saving the part. A while ago the map structure changed and the rule files where moved so i reloaded the rules in inventor but every time i use the a event trigger inventor gives an error it cant fint the rule, but when i run in manualy from the iLogic Browser it runs fine.
Anyone got a solution for this?
