Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
ilogic dxf sheet metal export issue
1 REPLY 1
gazadder
834 Views, 1 Reply
I have some some code as below that I use to export flat patterns of parts to dxf. Basically what the code does go through unsupressed parts iproperties and looks for a value called "ISM" in the iproperties - summery - keywords, if this value is present then it produces a dxf of the part.
95% of the time it works but occasionally I get the below error message. There seems to be no pattern to when it appears but more likely after one of the parts is unsupressed and before a save of the assembly. However, after not working 2 or 3 times it suddenly begins to work again.
Error in rule: DXF, in document: IMPELLER.iam
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
Does anyone know of a reason why the a code below may be vunerable to occasionally not working? (Using Inventor 2014)
Example of code used below:-
DXF_LOC = ThisDoc.Path & "\IMPELLER_DXF\"
part_no = 1
Dim oDoc As Document
Dim asmDoc As AssemblyDocument
asmDoc = ThisApplication.ActiveDocument
Dim asmDef As AssemblyComponentDefinition
asmDef = asmDoc.ComponentDefinition
Dim oComp As Inventor.ComponentOccurrence
For Each oDoc In ThisApplication.ActiveDocument.AllReferencedDocuments
Dim filename As String = IO.Path.GetFileName(oDoc.displayname)
oDocName = oDoc.Displayname
iProperties.Value(oDocName ,"Summary", "Title") = oDocName
    If iProperties.Value(oDocName ,"Summary", "Keywords") = "ISM" Then
    iProperties.Value(oDocName ,"Project", "Part Number") = JOB_NUMBER & "I" & part_no & ".dxf"
    Dim oCompDef As SheetMetalComponentDefinition
    oCompDef = oDoc.ComponentDefinition
        If oCompDef.HasFlatPattern = False Then
        oCompDef.Unfold
        oDoc.Save
        oDoc.Close
        End If
    Dim sOut As String
    sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_ROLL_TANGENT;IV_ARC_CENTERS"
    Dim sFname As String
    sFname = DXF_LOC & iProperties.Value(oDocName ,"Project", "Part Number") & ".dxf"
    oCompDef.DataIO.WriteDataToFile(sOut, sFname)
    part_no = part_no + 1
      End If
Next
1 REPLY 1
adam.nagy
in reply to: gazadder
You mentioned unsuppressing things. If a component is suppressed then you cannot access its ComponentDefinition.
So you might have to update the document after unsuppressing components in it.
That could be one reason.
One way to debug something like this is to place the code part in a Try/Catch, and inside the Catch part show a message with the name of the component you had issues with. That could give you a clue.
Cheers,
Adam Nagy
Autodesk Platform Services
