ilogic-Drawing
6 REPLIES 6
688 Views, 6 Replies
ilogic-Drawing
I have one query, It may require some API customization.
Suppose I had created 3 drawings say "Large.idw", "medium.idw" and small.idw" reference to one assembly file.
I had created three variants using i-Logic say small, medium and large.iam.
Let say, in each drawings , I had created unique annotations, BOM, manual dimensions and automatic dimensions for each drawing.
I want to write a code in such a way that, whenever I call and edit Large, medium or small configuration, it has to launch "Large.idw", "medium.idw" and small.idw" with associated changes.
Finally, If I change the configuration to large, medium and small ,  unique annotations and manual dimensions  given to respective ".idw's" must be restricted to respective sheets and should not override.
Actually, is not how Inventor works. Even if you create multiple drawings (ex. large.idw, medium.idw and small.idw) for different states, they will still refer to the current state of model.
Is there anyway to do it?
Please help me in this regard.
Currently i am using  publishing PDF files because there is no link to the model.
6 REPLIES 6
theo.bot
It's normal behavoir For inventor. But if you want to control it. I would suggest use datamanagement, so you can refer to the revision state of a drawing not the latest version.
Or stay in Inventor and use the "defer update option" in the document setting of your drawing. If you open the drawing he will remain in his last saved state.
You can control this option thru the API.
Succes,
Theo
in reply to: theo.bot
Thanks for your mail.
I appreciate your support on same.
How to control  the "defer update option" in the document setting of drawing thru the API.
If you have done this, may i please get the API code for the same.
Look forward for your reply.
theo.bot
Thanks a lot
Thanks a lot
I would like to run a ilogic rule in any assembly environment so that it has to allow me to rename components in series say "A01, A02....or PJ12, PJ13 or in any series ". I had tried the code, please refer to the attachment, this code worked well, it had renamed all the components in assembly environment. But when I open the part file in a separate window, the component name is reverted back to original one before applying the iLogic code mentioned in the attachement. Please let me know how to fix this.
Mahesh
