I would like to enable/suppress certain features in a part or assembly when entering FEA environment.
I have looked at the tips in http://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/discussion/t5/Inventor-Cu...
, but FEA doesn't report as an environment in that context, and i can't find it using the VBA object browser.
Any good tips?
Cheers
Jens
Solved by wayne.brill. Go to Solution.
Hi Jens,
The Inventor API has the UserInterfaceEvents.OnEnvironmentChange Event that may provide a way to do what you need. iLogic has Event Triggers but it does not include any event trigger that would run a rule when the environment changes.
Here is a VBA example to show the idea. (just to show the API). This example is suppressing/unsuppressing components in an assembly when the environment changes. Suppressing features would be similar.
Put this in a Class Module:
Private WithEvents UIE As UserInterfaceEvents
Private Sub Class_Initialize()
Set UIE = ThisApplication.UserInterfaceManager.UserInterfaceEvents
End Sub
Private Sub Class_Terminate()
Set UIE = Nothing
End Sub
Private Sub UIE_OnEnvironmentChange(ByVal Environment As Environment, ByVal EnvironmentState As EnvironmentStateEnum, ByVal BeforeOrAfter As EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum)
'Debug.Print Environment.DisplayName
'Debug.Print BeforeOrAfter
If Environment.DisplayName = "Assembly" Then
If BeforeOrAfter = kAfter Then
If ThisApplication.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oCO As ComponentOccurrence
For Each oCO In oAsmDoc.ComponentDefinition.Occurrences
Debug.Print oCO.Name
If oCO.Name = "EndPlate_Simple:1" Then
If oCO.Suppressed = False Then
Call oCO.Suppress
Else
Call oCO.Unsuppress
Next
End Sub
Put this in a Module:
Dim oCls As clsUIE
Sub startE()
Set oCls = New clsUIE
End Sub
Sub stopE()
Set oCls = Nothing
End Sub
Run startE() to enable the event.
Wayne
Hi Wayne,
I'm sorry it took so long for me to see your answer, i don't visit here often, and back then i had to just finish up and deliver.
However, i do appreciate your effort and i will try it out when i get a chance.
Thank you.
Cheers Jens
