Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic - delete all erroneous iMates
2 REPLIES 2
waynehelley
535 Views, 2 Replies
Hi there,
I have some code I use to delete all assembly constraint errors...
Dim oAssDoc As AssemblyDocument
oAssDoc = ThisApplication.ActiveDocument
Dim oConstraint As AssemblyConstraint
RUSure = MessageBox.Show _
("Are you sure you want to Delete all sick constraints?", _
"iLogic",MessageBoxButtons.YesNo)
If RUSure = vbNo Then
Return
Else
i = 0
For Each oConstraint In oAssDoc.ComponentDefinition.Constraints
If oConstraint.HealthStatus <> oConstraint.HealthStatus.kUpToDateHealth And _
oConstraint.HealthStatus <> oConstraint.HealthStatus.kSuppressedHealth Then
oConstraint.Delete
i = i + 1
Next
MessageBox.Show(" A total of "& i & " constraints were deleted.", "iLogic")
I would like it to make it work with iMates too!  Does anybody know if this is possible?
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Tags (2)
2 REPLIES 2
Yadow
in reply to: waynehelley
I´m currently looking for this solution as well. Have you had any progress? 🙂
waynehelley
in reply to: Yadow
I never found a solution at the time and I'm no longer at the company I was at so I don't actually have an example to test.  I have had a little look around in the API and something like this might work.
Dim iMate As iMateResult
For Each iMate In oAssDoc.ComponentDefinition.iMateResults
For Each oConstraint In iMate.Constraints
oConstraint.Delete()
Next
Next
Wayne Helley
Visual Studio 2022
