Hi there,
I have some code I use to delete all assembly constraint errors...
Dim oAssDoc As AssemblyDocument
oAssDoc = ThisApplication.ActiveDocument
Dim oConstraint As AssemblyConstraint
RUSure = MessageBox.Show _
("Are you sure you want to Delete all sick constraints?", _
"iLogic",MessageBoxButtons.YesNo)
If RUSure = vbNo Then
Return
Else
i = 0
For Each oConstraint In oAssDoc.ComponentDefinition.Constraints
If oConstraint.HealthStatus <> oConstraint.HealthStatus.kUpToDateHealth And _
oConstraint.HealthStatus <> oConstraint.HealthStatus.kSuppressedHealth Then
oConstraint.Delete
i = i + 1
End If
Next
End If
MessageBox.Show(" A total of "& i & " constraints were deleted.", "iLogic")
I would like it to make it work with iMates too! Does anybody know if this is possible?
I never found a solution at the time and I'm no longer at the company I was at so I don't actually have an example to test. I have had a little look around in the API and something like this might work.
Dim iMate As iMateResult
For Each iMate In oAssDoc.ComponentDefinition.iMateResults
For Each oConstraint In iMate.Constraints
oConstraint.Delete()
End If
Next
Next
