I've searched the forum and seen several posts which were helpful, but I keep running into my own ignorance and can't quite get things to work. There will be several ways to solve this, some more robust than others. Right now I'd just like to get it working as simply as possible!
I want to have a template IDW containing sketched symbols representing various possible drawing status stamps; when the drawing is ready for publish I want to run a rule which allows selection of one stamp for insertion on the drawing. For right now, I'm just interested in how to copy the symbol from the one drawing to the other. Here is my nonworking code:
'Query stamp insertion requirement question = MessageBox.Show("Do you want to insert a stamp?", "Stamp Requirement",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If question = vbYes Then Dim strSelectedStamp As String = "Result2" Dim strStampList As New ArrayList strStampRequired = True strStampList.Add("F&C Stamp Round") strStampList.Add("As-Built Stamp Round") strStampList.Add("Test") strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps") Dim strDrawDoc As Inventor.DrawingDocument: strDrawingDoc = ThisApplication.ActiveDocument Dim SourceFile As String = "D:\Local Server\Data\Autodesk Customization\Templates\IV2014Stamps.idw" Dim strSourceIDW As DrawingDocument strSourceIDW = ThisApplication.Documents.Open(SourceFile, False) Dim symbolDef As SketchedSymbolDefinition For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions If (StrComp(symbolDef.Name,strSelectedStamp,vbTextCompare)=0)Then CopyFrom = symbolDef.CopyTo(strDrawDoc, True) End If Next
I get a 'The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))' error. Any ideas what I am doing wrong and how to fix it?
Thanks for the help!
Solved by Mike.Wohletz. Go to Solution.
try this out and let me know if it is what you are looking for.
'Query stamp insertion requirement question = MessageBox.Show("Do you want to insert a stamp?", "Stamp Requirement", MessageBoxButtons.YesNo, MessageBoxIcon.Question) If question = vbYes Then Dim strSelectedStamp As String = "Result2" Dim strStampList As New ArrayList strStampRequired = True 'strStampList.Add("F&C Stamp Round") 'strStampList.Add("As-Built Stamp Round") 'strStampList.Add("Test") 'strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps") Dim strDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument Dim SourceFile As String = "D:\Local Server\Data\Autodesk Customization\Templates\IV2014Stamps.idw" Dim strSourceIDW As DrawingDocument strSourceIDW = ThisApplication.Documents.Open(SourceFile, False) Dim symbolDef As SketchedSymbolDefinition For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions strStampList.Add(symbolDef.Name) Next strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps") For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions If (StrComp(symbolDef.Name, strSelectedStamp, vbTextCompare) = 0) Then CopyFrom = symbolDef.CopyTo(strDrawDoc, True) End If Next strSourceIDW.Close() End If
Thanks for that! It worked beautifully, and better than I expected. May I ask another question, or should I post under a new topic?
Later in my code I want to take the selected symbol and place it on a drawing sheet. If I code in the symbol name where I show XXXXX below, it inserts the symbol as expected. How do I get it to insert the selected symbol using a string/variable?
'Insert stamp if required If strStampRequired = True Then Dim strDrawDoc As DrawingDocument = ThisDrawing.Document Dim strSketchedSymbolDef As SketchedSymbolDefinition = strDrawDoc.SketchedSymbolDefinitions.Item(XXXXX) Dim strTransGeom = ThisApplication.TransientGeometry Dim strInsertionPoint As Point2d = strTransGeom.CreatePoint2d(5.5,13) Dim strSketchedSymbol As SketchedSymbol = strSheet.SketchedSymbols.Add(strSketchedSymbolDef,strInsertionPoint,0,0.75,Nothing) Else End If
Any ideas how to fix it? I thought I could substitute strSelectedStamp for the XXXXX, but that causes the earlier code to error with 'Variable 'strSelectedStamp' hides a variable in an enclosing block' on the line 'Dim strSelectedStamp As String = "Result2". I'd like to understand what I'm doing wrong...
I think that something like this is what you are after. let me know if this is the proper solution to your question.
Sub Main() 'Query stamp insertion requirement question = MessageBox.Show("Do you want to insert a stamp?", "Stamp Requirement", MessageBoxButtons.YesNo, MessageBoxIcon.Question) If question = vbYes Then Dim strSelectedStamp As String = "Result2" Dim strStampList As New ArrayList strStampRequired = True 'strStampList.Add("F&C Stamp Round") 'strStampList.Add("As-Built Stamp Round") 'strStampList.Add("Test") 'strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps") Dim strDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument Dim SourceFile As String = "D:\Local Server\Data\Autodesk Customization\Templates\IV2014Stamps.idw" Dim strSourceIDW As DrawingDocument strSourceIDW = ThisApplication.Documents.Open(SourceFile, False) Dim symbolDef As SketchedSymbolDefinition For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions strStampList.Add(symbolDef.Name) Next strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps") For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions If (StrComp(symbolDef.Name, strSelectedStamp, vbTextCompare) = 0) Then CopyFrom = symbolDef.CopyTo(strDrawDoc, True) If MsgBox("Would you like to place the stamp on the drawing?", MsgBoxStyle.YesNo, "Insert Stamp") = MsgBoxResult.Yes Then 'Insert stamp if required InsertSymbol(symbolDef.Name) End If End If Next strSourceIDW.Close() End If End Sub Private Sub InsertSymbol(ByVal SymbName As String) Dim strDrawDoc As DrawingDocument = ThisDrawing.Document Dim strSheet As Sheet = strDrawDoc.ActiveSheet Dim strSketchedSymbolDef As SketchedSymbolDefinition = strDrawDoc.SketchedSymbolDefinitions.Item(SymbName) Dim strTransGeom = ThisApplication.TransientGeometry Dim strInsertionPoint As Point2d = strTransGeom.CreatePoint2d(5.5, 13) Dim strSketchedSymbol As SketchedSymbol = strSheet.SketchedSymbols.Add(strSketchedSymbolDef, strInsertionPoint, 0, 0.75, Nothing) End Sub
Thanks again! Your code runs perfectly as intended when I run it as its own rule.
Unfortunately, I am doing some things in between loading the symbol and placing it on the sheet. I'll try to describe, rather than posting the whole rule as it is quite long and probably terrible.
We prefer to use multisheet IDWs. The limiting factor historically has been a populated titleblock for each sheet: the file sizes and memory requirements were just too burdensome, so operationally had a macro which split the idw into individual IV.dwg sheets and then added the titleblock populated from a spreadsheet. The spreadsheet is nice; it tracks our revision history for an entire document set.
Now we are trying something similar in iLogic, and my rule first specifies the border, titleblock, and stamp (which will be the same for all sheets) and then steps through each sheet adding the border, titleblock and stamp if required, populates the titleblock with custom iproperties read in from the spreadsheet, saves/exports the resultant to ACAD dwg and pdf, and then deletes the same from that sheet before continuing to the next sheet. At any given time, the IDW custom iProperties contain sufficient data to populate only one sheet's titleblock.
Consequently, I'd like to call subInsertSymbol to the active sheet immediately before the sheet is exported, but if I move InsertSymbol(symbolDef.Name) it seems symbolDef becomes 'not declared'...at least that is the error I am getting. Here is just a snip of the code showing the last of assigning values to the iProperties through to the start of publishing, all in Sub Main():
iProperties.Value("Custom", "PROJECTTITLE1-2") = strProjTitle2 iProperties.Value("Custom", "FILENUM2") = strFileNum2 iProperties.Value("Custom", "AREA/FACILITY") = strAreaFac iProperties.Value("Custom", "DOC/TYPE") = strDocType 'Insert the border on the active sheet ActiveSheet.Border = "HEL" 'Insert the titleblock on the active sheet ActiveSheet.TitleBlock = strSelectedTB 'Insert stamp if required If strStampRequired = True Then InsertSymbol(symbolDef.Name) 'Dim strDrawDoc As DrawingDocument = ThisDrawing.Document 'Dim strSketchedSymbolDef As SketchedSymbolDefinition = strDrawDoc.SketchedSymbolDefinitions.Item(strSelectedStamp) 'Dim strTransGeom = ThisApplication.TransientGeometry 'Dim strInsertionPoint As Point2d = strTransGeom.CreatePoint2d(5.5,13) 'Dim strSketchedSymbol As SketchedSymbol = strSheet.SketchedSymbols.Add(strSketchedSymbolDef,strInsertionPoint,0,0.75,Nothing) Else End If MessageBox.Show("All properties have been applied to " & strCurrentSeqNum, "Title Block Data Status") '---------------Export the sheet to pdf------------------------ 'Assign path and file name strFullFileName = strPdfFolder & "\" & strFileNum2 & ".pdf" strPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") strDocument = ThisApplication.ActiveDocument
Am I declaring symbolDef in the wrong location for it to be available throughout?
Here's the entire rule...I've put <snipped for length> where I've taken out repetitive data:
Public Sub Main() 'Check if publish rule intentional question = MessageBox.Show("Ready to commence publishing?", "Confirm Publish",MessageBoxButtons.YesNo,MessageBoxIcon.Question) If question = vbNo Then Return Else End If 'Define pdf and dwg file locations strPublishedFolder = ThisDoc.Path & "\Published" 'Make output folders if they don't exist strPdfFolder = strPublishedFolder & "\PDF" If Dir(strPdfFolder, vbDirectory) = "" Then MkDir (strPdfFolder) strDwgFolder = strPublishedFolder & "\DWG" If Dir(strDwgFolder, vbDirectory) = "" Then MkDir (strDwgFolder) 'Title block selection from external file ThisDrawing.ResourceFileName = "D:\Local Server\Data\Autodesk Customization\Templates\IV2014TitleBlocks.idw" ThisDrawing.KeepExtraResources = False Dim strSelectedTB As String = "Result" Dim strTitleBlock As New ArrayList strTitleBlock.Add("EMAL") strTitleBlock.Add("EmalP2") strTitleBlock.Add("KMP") strSelectedTB = InputListBox("Select a Title Block", strTitleBlock, strSelectedTB, "Title Block Selection", "Available Title Blocks") 'Query stamp insertion requirement question = MessageBox.Show("Do you want to insert a stamp?", "Stamp Requirement", MessageBoxButtons.YesNo, MessageBoxIcon.Question) If question = vbYes Then Dim strSelectedStamp As String = "Result2" Dim strStampList As New ArrayList strStampRequired = True Dim strDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument Dim SourceFile As String = "D:\Local Server\Data\Autodesk Customization\Templates\IV2014Stamps.idw" Dim strSourceIDW As DrawingDocument strSourceIDW = ThisApplication.Documents.Open(SourceFile, False) Dim symbolDef As SketchedSymbolDefinition For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions strStampList.Add(symbolDef.Name) Next strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps") For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions If (StrComp(symbolDef.Name, strSelectedStamp, vbTextCompare) = 0) Then CopyFrom = symbolDef.CopyTo(strDrawDoc, True) End If Next strSourceIDW.Close() MessageBox.Show("You have selected " & strSelectedStamp, "Stamp Selection Feedback") Else strStampRequired = False End If 'Step through each sheet in the IDW Dim strSheets As Sheets strSheets = ThisDoc.Document.sheets Dim strSheet As Sheet For Each strSheet In strSheets strSheet.activate 'Truncate the sheet instance from the sheet name, keeping the digits before the colon SheetName = ActiveSheet.Name ColonIndex = SheetName.LastindexOf(":") strCurrentSeqNum = SheetName.substring(0,ColonIndex) 'Access the Titleblock Data spreadsheet and select the row corresponding to the active drawing sheet i = GoExcel.FindRow("TBData.xlsx", "Sheet1", "SEQNO", "=", strCurrentSeqNum) 'Get the cell values for the designated row strArea = GoExcel.CurrentRowValue("AREA") <snipped for length> strDocType = GoExcel.CurrentRowValue("DOC/TYPE") 'Populate the Custom iProperties with the TBData values iProperties.Value("Custom", "AREA") = strArea <snipped for length> iProperties.Value("Custom", "DOC/TYPE") = strDocType 'Insert the border on the active sheet ActiveSheet.Border = "HEL" 'Insert the titleblock on the active sheet ActiveSheet.TitleBlock = strSelectedTB 'Insert stamp if required If strStampRequired = True Then InsertSymbol(symbolDef.Name) 'Dim strDrawDoc As DrawingDocument = ThisDrawing.Document 'Dim strSketchedSymbolDef As SketchedSymbolDefinition = strDrawDoc.SketchedSymbolDefinitions.Item(strSelectedStamp) 'Dim strTransGeom = ThisApplication.TransientGeometry 'Dim strInsertionPoint As Point2d = strTransGeom.CreatePoint2d(5.5,13) 'Dim strSketchedSymbol As SketchedSymbol = strSheet.SketchedSymbols.Add(strSketchedSymbolDef,strInsertionPoint,0,0.75,Nothing) Else End If MessageBox.Show("All properties have been applied to " & strCurrentSeqNum, "Title Block Data Status") '---------------Export the sheet to pdf------------------------ 'Assign path and file name strFullFileName = strPdfFolder & "\" & strFileNum2 & ".pdf" strPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") strDocument = ThisApplication.ActiveDocument strContext = ThisApplication.TransientObjects.CreateTranslationContext strContext.Type = IOMechanismEnum.kFileBrowseIOMechanism strOptions = ThisApplication.TransientObjects.CreateNameValueMap strDataMedium = ThisApplication.TransientObjects.CreateDataMedium If strPDFAddIn.HasSaveCopyAsOptions(strDataMedium, strContext, strOptions) Then strOptions.Value("All_Color_AS_Black") = 0 strOptions.Value("Remove_Line_Weights") = 0 strOptions.Value("Vector_Resolution") = 400 strOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet End If 'Set the PDF target file name strDataMedium.FileName = strFullFileName 'Publish document as PDF strPDFAddIn.SaveCopyAs(strDocument, strContext, strOptions, strDataMedium) '----------- export the sheet to dwg ------------------- 'Assign path and file name strFullFileName = strDwgFolder & "\" & strFileNum2 & ".dwg" ' Get the DWG translator Add-In. strDWGAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") strContext = ThisApplication.TransientObjects.CreateTranslationContext strContext.Type = IOMechanismEnum.kFileBrowseIOMechanism strOptions = ThisApplication.TransientObjects.CreateNameValueMap strDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If strDWGAddIn.HasSaveCopyAsOptions(strDocument, strContext, strOptions) Then ' DWG version. ' 23 = ACAD 2000 ' 25 = ACAD 2004 ' 27 = ACAD 2007 ' 29 = ACAD 2010 strOptions.Value("DwgVersion") = 27 Dim strIniFile As String strIniFile = "D:\Local Server\Data\Heaslip Autodesk Customization\Templates\DWGSubmittalConfig.ini" ' Create the name-value that specifies the ini file to use. strOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the DWG target file name strDataMedium.FileName = strFullFileName 'Publish the active sheet as DWG 2007 strDWGAddIn.SaveCopyAs(strDocument, strContext, strOptions, strDataMedium) 'Delete the titleblock, border, and stamp from the current sheet before continuing to the next sheet strSheet.TitleBlock.Delete() strSheet.Border.Delete() 'MessageBox.Show("Sheet " & strCurrentSeqNum & " has successfully been exported", "Sheet Publish Status") Next MessageBox.Show("Publishing Completed","") End Sub Private Sub InsertSymbol(ByVal SymbName As String) Dim strDrawDoc As DrawingDocument = ThisDrawing.Document Dim strSheet As Sheet = strDrawDoc.ActiveSheet Dim strSketchedSymbolDef As SketchedSymbolDefinition = strDrawDoc.SketchedSymbolDefinitions.Item(SymbName) Dim strTransGeom = ThisApplication.TransientGeometry Dim strInsertionPoint As Point2d = strTransGeom.CreatePoint2d(5.5, 13) Dim strSketchedSymbol As SketchedSymbol = strSheet.SketchedSymbols.Add(strSketchedSymbolDef, strInsertionPoint, 0, 0.75, Nothing) End Sub
Thanks...
Ok I see that the property is declared inside an IF statement and then tried to be used outside of that. This is not posible to do insise of an IF or loop so when this is the case you will need to set something of a declared variable or public property decalared outside of this to make it available through the process. I have included that I think will work for you below.
Public Sub Main() 'Check if publish rule intentional Dim SymbolName As String = Nothing ' we are going to declare this and set it to nothing early in the game and use it later question = MessageBox.Show("Ready to commence publishing?", "Confirm Publish", MessageBoxButtons.YesNo, MessageBoxIcon.Question) If question = vbNo Then Return Else End If 'Define pdf and dwg file locations strPublishedFolder = ThisDoc.Path & "\Published" 'Make output folders if they don't exist strPdfFolder = strPublishedFolder & "\PDF" If Dir(strPdfFolder, vbDirectory) = "" Then MkDir(strPdfFolder) strDwgFolder = strPublishedFolder & "\DWG" If Dir(strDwgFolder, vbDirectory) = "" Then MkDir(strDwgFolder) 'Title block selection from external file ThisDrawing.ResourceFileName = "D:\Local Server\Data\Autodesk Customization\Templates\IV2014TitleBlocks.idw" ThisDrawing.KeepExtraResources = False Dim strSelectedTB As String = "Result" Dim strTitleBlock As New ArrayList strTitleBlock.Add("EMAL") strTitleBlock.Add("EmalP2") strTitleBlock.Add("KMP") strSelectedTB = InputListBox("Select a Title Block", strTitleBlock, strSelectedTB, "Title Block Selection", "Available Title Blocks") 'Query stamp insertion requirement question = MessageBox.Show("Do you want to insert a stamp?", "Stamp Requirement", MessageBoxButtons.YesNo, MessageBoxIcon.Question) If question = vbYes Then Dim strSelectedStamp As String = "Result2" Dim strStampList As New ArrayList strStampRequired = True Dim strDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument Dim SourceFile As String = "D:\Local Server\Data\Autodesk Customization\Templates\IV2014Stamps.idw" Dim strSourceIDW As DrawingDocument strSourceIDW = ThisApplication.Documents.Open(SourceFile, False) Dim symbolDef As SketchedSymbolDefinition For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions strStampList.Add(symbolDef.Name) Next strSelectedStamp = InputListBox("Please select a stamp.", strStampList, strSelectedStamp, "Stamp Selection", "Available Stamps") For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions If (StrComp(symbolDef.Name, strSelectedStamp, vbTextCompare) = 0) Then CopyFrom = symbolDef.CopyTo(strDrawDoc, True) SymbolName = symbolDef.Name End If Next strSourceIDW.Close() MessageBox.Show("You have selected " & strSelectedStamp, "Stamp Selection Feedback") Else strStampRequired = False End If 'Step through each sheet in the IDW Dim strSheets As Sheets strSheets = ThisDoc.Document.sheets Dim strSheet As Sheet For Each strSheet In strSheets strSheet.activate() 'Truncate the sheet instance from the sheet name, keeping the digits before the colon SheetName = ActiveSheet.Name ColonIndex = SheetName.LastindexOf(":") strCurrentSeqNum = SheetName.substring(0, ColonIndex) 'Access the Titleblock Data spreadsheet and select the row corresponding to the active drawing sheet i = GoExcel.FindRow("TBData.xlsx", "Sheet1", "SEQNO", "=", strCurrentSeqNum) 'Get the cell values for the designated row strArea = GoExcel.CurrentRowValue("AREA") '<snipped for length> strDocType = GoExcel.CurrentRowValue("DOC/TYPE") 'Populate the Custom iProperties with the TBData values iProperties.Value("Custom", "AREA") = strArea '<snipped for length> iProperties.Value("Custom", "DOC/TYPE") = strDocType 'Insert the border on the active sheet ActiveSheet.Border = "HEL" 'Insert the titleblock on the active sheet ActiveSheet.TitleBlock = strSelectedTB 'Insert stamp if required If strStampRequired = True And Not SymbolName Is Nothing Then ' we will make sure it is wanted and also check that the property declared ' at the top of this sub was set to something so we dont pass an empty string InsertSymbol(SymbolName) 'Dim strDrawDoc As DrawingDocument = ThisDrawing.Document 'Dim strSketchedSymbolDef As SketchedSymbolDefinition = strDrawDoc.SketchedSymbolDefinitions.Item(strSelectedStamp) 'Dim strTransGeom = ThisApplication.TransientGeometry 'Dim strInsertionPoint As Point2d = strTransGeom.CreatePoint2d(5.5,13) 'Dim strSketchedSymbol As SketchedSymbol = strSheet.SketchedSymbols.Add(strSketchedSymbolDef,strInsertionPoint,0,0.75,Nothing) Else End If MessageBox.Show("All properties have been applied to " & strCurrentSeqNum, "Title Block Data Status") '---------------Export the sheet to pdf------------------------ 'Assign path and file name strFullFileName = strPdfFolder & "\" & strFileNum2 & ".pdf" strPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") strDocument = ThisApplication.ActiveDocument strContext = ThisApplication.TransientObjects.CreateTranslationContext strContext.Type = IOMechanismEnum.kFileBrowseIOMechanism strOptions = ThisApplication.TransientObjects.CreateNameValueMap strDataMedium = ThisApplication.TransientObjects.CreateDataMedium If strPDFAddIn.HasSaveCopyAsOptions(strDataMedium, strContext, strOptions) Then strOptions.Value("All_Color_AS_Black") = 0 strOptions.Value("Remove_Line_Weights") = 0 strOptions.Value("Vector_Resolution") = 400 strOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet End If 'Set the PDF target file name strDataMedium.FileName = strFullFileName 'Publish document as PDF strPDFAddIn.SaveCopyAs(strDocument, strContext, strOptions, strDataMedium) '----------- export the sheet to dwg ------------------- 'Assign path and file name strFullFileName = strDwgFolder & "\" & strFileNum2 & ".dwg" ' Get the DWG translator Add-In. strDWGAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") strContext = ThisApplication.TransientObjects.CreateTranslationContext strContext.Type = IOMechanismEnum.kFileBrowseIOMechanism strOptions = ThisApplication.TransientObjects.CreateNameValueMap strDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If strDWGAddIn.HasSaveCopyAsOptions(strDocument, strContext, strOptions) Then ' DWG version. ' 23 = ACAD 2000 ' 25 = ACAD 2004 ' 27 = ACAD 2007 ' 29 = ACAD 2010 strOptions.Value("DwgVersion") = 27 Dim strIniFile As String strIniFile = "D:\Local Server\Data\Heaslip Autodesk Customization\Templates\DWGSubmittalConfig.ini" ' Create the name-value that specifies the ini file to use. strOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the DWG target file name strDataMedium.FileName = strFullFileName 'Publish the active sheet as DWG 2007 strDWGAddIn.SaveCopyAs(strDocument, strContext, strOptions, strDataMedium) 'Delete the titleblock, border, and stamp from the current sheet before continuing to the next sheet strSheet.TitleBlock.Delete() strSheet.Border.Delete() 'MessageBox.Show("Sheet " & strCurrentSeqNum & " has successfully been exported", "Sheet Publish Status") Next MessageBox.Show("Publishing Completed", "") End Sub Private Sub InsertSymbol(ByVal SymbName As String) Dim strDrawDoc As DrawingDocument = ThisDrawing.Document Dim strSheet As Sheet = strDrawDoc.ActiveSheet Dim strSketchedSymbolDef As SketchedSymbolDefinition = strDrawDoc.SketchedSymbolDefinitions.Item(SymbName) Dim strTransGeom = ThisApplication.TransientGeometry Dim strInsertionPoint As Point2d = strTransGeom.CreatePoint2d(5.5, 13) Dim strSketchedSymbol As SketchedSymbol = strSheet.SketchedSymbols.Add(strSketchedSymbolDef, strInsertionPoint, 0, 0.75, Nothing) End Sub
Could you help me. How to create ilogic rule for One Sketched Symbol without messege:
