Ilogic command to republish dwf file...
7 REPLIES 7
Message 1 of 8
Ion01
487 Views, 7 Replies
I would like to use code to open a dwf markup and then republish the markup. Here is the code for the first step of making the dwf for the next person to check and mark up:
opath = ThisDoc.WorkspacePath()
oname = ThisDoc.FileName(False) ' without extension
DWFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If DWFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("Launch_Viewer") = launchviewer
oOptions.Value("Publish_All_Component_Props") = 1
oOptions.Value("Publish_All_Physical_Props") = 1
oOptions.Value("Password") = 0
End If
'Set the destination file name
oDataMedium.FileName = opath & "\Markups\Check\" & oname & ".dwf"
'Publish document.
Call DWFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Once the dwf has been marked up I have the follwoing simple code to open the dwf as an overlay on the idw:
ThisApplication.Documents.Open(opath & "\Markups\Check\" & oname & ".dwf")
Now I want code to use the  republish all sheets command and dont know how to go about that..... If I run the code I already use it doesn't retain the markups and just publishes a new dwf but I need to retain the markup history and the republish all sheets command does this but I don't know how to call that in Ilogic. Any help would be great! Thanks!
7 REPLIES 7
Message 2 of 8
adam.nagy
in reply to: Ion01
Unfortunately, I did not find a DWF publish option for republish. I also did not find the ControlDefinition for it and no Command is triggered when you click "Republish Markup Sheets"
So it's not looking good 😞
I'll check if perhaps that option was just left out of the help file but actually is implemented in the API.
Cheers,
Adam Nagy
Autodesk Platform Services
Message 3 of 8
adam.nagy
in reply to: adam.nagy
I checked the list of control definitions before opening the drawing :-s
My colleague pointed out that the AddIn does provide ControlDefinitions, so you can achieve what you want. 🙂
I wrote a blog post about this:
http://adndevblog.typepad.com/manufacturing/2014/10/republish-markup-sheets.html
Cheers,
Adam Nagy
Message 4 of 8
Ion01
Thanks for the help adam. I have a problem though. I copied your code directly into a new Rule. I make sure I have a markup overlay then run the code and first I got a message saying set is no longer supported so I simply removed the word set. Next I get Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
I don't know what to do to fix it.....I am using inventor pro 2014
Message 5 of 8
adam.nagy
in reply to: Ion01
Updated the blog post with iLogic code.
Hope that works for you.
Cheers,
Adam Nagy
Message 6 of 8
Ion01
Thanks! That was a huge help! I was able to use the open and close DWF pieces as well so the blog was helpful!
Message 7 of 8
Ion01
Well I thought it was working well and the code does but now it messes with inventor. For instance after running the code it will make every time I hit the open icon it brings in the overlay or if I hit save it makes a dwf.....
Here is the code I have:
SyntaxEditor Code Snippet
On Error Resume Next
ThisApplication.Documents.Open(opath & "\Markups\Needs Revision\" & oname & ".dwf")
 Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
' Get the collection of control definitions
Dim oControlDefs As ControlDefinitions
oControlDefs = oCommandMgr.ControlDefinitions
Call oCommandMgr.PostPrivateEvent(
  PrivateEventTypeEnum.kFileNameEvent,opath & "\Markups\Needs Revision\" & oname & "1.dwf")
Call oControlDefs(
  "MarkupManager:Command: DWF Republish Markup Sheets").Execute
Call oControlDefs(
  "MarkupManager:Command: DWF File Close").Execute
System.IO.File.Delete(opath & "\Markups\Needs Revision\" & oname & ".dwf")
ThisDoc.Launch(opath & "\Markups\Needs Revision\")
Message 8 of 8
wayne.brill
in reply to: Ion01
Here is a suggestion to try:
Use
oControlDefs("Command Name").Execute2(True)
instead of
That will execute the command synchronously. It will wait for the command to finish before continuing to the next program statement.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
