Hi all,
I'm attempting to create a model that autmotaically derives ready-to-go drawings. I've gotten pretty far in doing so but have a few issues with regards to dimensioning. As I'm sure you're aware, when the model changes, a dimension to that feature, which has been removed, is also deleted and some those dimensions do not return once the model is changed back.
I have looked into using different view representations, but have found that they do not accommodate feature supression.
My questions are:
Is there a way to program in the dimensioning of a view
Create center points for of of the holes and center lines
And for a feature note such as "Hole and Thread" dimensioning, when the model expands, the leader and text length do not change and proceed into the view. Is there a way to fix or anchor the text to a certain spot on the drawing, and have the leader length expand and change accordingly to that point.
If you would like farther information, or think a similar question would help, please ask. Thanks in advance for any help.
Mitch
Hi Shiva,
I'm not quite sure I understand your question. Are you asking if there is any way to use this code in the drawing file instead of running it from the assembly?
The code I created was designed to run from the assembly file at the start, the dimensioning functions should be fine to run within the drawing itself.
Can you please give a more descrptive scenario of what you're trying to do? I believe I can help you, I just need a better understanding.
For the dimensioning between circles, the first thing I would go through is to check your model, parameters, and dimension you're entering into the code. Inventor is very sensitive and if the dimension is some how 0.000001 off, iLogic will not be able to locate it in the drawing.
Regards
Mitch
This is VBA Code for automatic creation of Drawings in Assembly file. Here i got one small difficulty, while creations of section views
In that attachment code,
' Get the circular edge of the top of the part.
Dim oObjs As ObjectCollection
Set oObjs = oAssemblyDoc.AttributeManager.FindObjects("Name", "Name", "Edge11")
Dim oCircularEdge As Edge
Set oCircularEdge = oObjs.Item(1)
Highlighted line got error in this code.
Pls find the suitable solutions for this
Option Explicit ' This creates a toolbar with buttons for the macros to be demonstrated. Public Sub CreateDemoToolbar() Dim oCommandBar As CommandBar Set oCommandBar = ThisApplication.UserInterfaceManager.CommandBars.Add("Drawing Automation Samples", "") oCommandBar.Visible = True ' Buttons for drawing view related samples. Set oMacroDef = ThisApplication.CommandManager.ControlDefinitions.AddMacroControlDefinition("modOverallDimensions.TestOverallDimensions") Call oCommandBar.Controls.AddMacro(oMacroDef) Set oMacroDef = ThisApplication.CommandManager.ControlDefinitions.AddMacroControlDefinition("modSamples.MakeDrawing") Call oCommandBar.Controls.AddMacro(oMacroDef) End Sub ' Demonstrates the ability to automatically create a drawing. It's hard coded to look for edges ' with specific attributes attached. The supplied model is already set up. Public Sub MakeDrawing() ' Create a new drawing document using the default template. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "dwg", True) Dim oSheet As Sheet Set oSheet = oDrawDoc.ActiveSheet ' Open the part to be inserted into the drawing. Dim oAssemblyDoc As AssemblyDocument Set oAssemblyDoc = ThisApplication.Documents.Open("Assembly.iam", False) Dim oTG As TransientGeometry Set oTG = ThisApplication.TransientGeometry MsgBox "Create base and orthographic views." ' Place the base front view. Dim oFrontView As DrawingView Set oFrontView = oSheet.DrawingViews.AddBaseView(oAssemblyDoc, oTG.CreatePoint2d(12, 15), 5, kFrontViewOrientation, kHiddenLineDrawingViewStyle) ' Create the top, right and iso views. Dim oTopView As DrawingView Set oTopView = oSheet.DrawingViews.AddProjectedView(oFrontView, oTG.CreatePoint2d(12, 30), kFromBaseDrawingViewStyle) Dim oIsoView As DrawingView Set oIsoView = oSheet.DrawingViews.AddProjectedView(oFrontView, oTG.CreatePoint2d(44, 33), kHiddenLineRemovedDrawingViewStyle) MsgBox "Create section view." ' Create a front section view by defining a section line in the front view. Dim oSectionSketch As DrawingSketch Set oSectionSketch = oFrontView.Sketches.Add oSectionSketch.Edit ' Get the circular edge of the top of the part. Dim oObjs As ObjectCollection Set oObjs = oAssemblyDoc.AttributeManager.FindObjects("Name", "Name", "Edge11") Dim oCircularEdge As Edge Set oCircularEdge = oObjs.Item(1) ' Get the associated drawingcurve. Dim oDrawViewCurves As DrawingCurvesEnumerator Set oDrawViewCurves = oFrontView.DrawingCurves(oCircularEdge) Dim oCircularCurve As DrawingCurve Set oCircularCurve = oDrawViewCurves.Item(1) Dim oCircularEntity As SketchEntity Set oCircularEntity = oSectionSketch.AddByProjectingEntity(oCircularCurve) ' Draw the section line. Dim oSectionLine As SketchLine Set oSectionLine = oSectionSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0, 0.9), oTG.CreatePoint2d(0, -0.9)) ' Create a constraint to the projected circle center point and the line. Call oSectionSketch.GeometricConstraints.AddCoincident(oSectionLine, oCircularEntity.CenterSketchPoint) oSectionSketch.ExitEdit ' Create the section view. Dim oSectionView As SectionDrawingView Set oSectionView = oSheet.DrawingViews.AddSectionView(oFrontView, oSectionSketch, oTG.CreatePoint2d(24, 10), kHiddenLineRemovedDrawingViewStyle, , False) MsgBox "Create detail view." ' Create the detail view. Dim oDetailView As DetailDrawingView Set oDetailView = oSheet.DrawingViews.AddDetailView(oSectionView, oTG.CreatePoint2d(35, 15), kFromBaseDrawingViewStyle, True, oTG.CreatePoint2d(23, 16), 2, , 5, , "A") ' Get the various edges of the model. Dim aoEdges(1 To 12) As Edge Dim i As Integer For i = 1 To 12 Set oObjs = oAssemblyDoc.AttributeManager.FindObjects("Name", "Name", "Edge" & i) Set aoEdges(i) = oObjs.Item(1) Next ' Get the equivalent drawing curves. Dim aoDrawCurves(1 To 12) As DrawingCurve For i = 1 To 12 Set oDrawViewCurves = oFrontView.DrawingCurves(aoEdges(i)) Set aoDrawCurves(i) = oDrawViewCurves.Item(1) Next MsgBox "Create dimensions to the curves in the view." ' Create some dimensions Dim oGeneralDims As GeneralDimensions Set oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions Dim oDim As GeneralDimension Set oDim = oGeneralDims.AddLinear(oTG.CreatePoint2d(7, 15), oSheet.CreateGeometryIntent(aoDrawCurves(1)), oSheet.CreateGeometryIntent(aoDrawCurves(3)), kVerticalDimensionType) Set oDim = oGeneralDims.AddLinear(oTG.CreatePoint2d(12, 9), oSheet.CreateGeometryIntent(aoDrawCurves(2)), oSheet.CreateGeometryIntent(aoDrawCurves(4)), kHorizontalDimensionType) Set oDim = oGeneralDims.AddRadius(oTG.CreatePoint2d(16, 19), oSheet.CreateGeometryIntent(aoDrawCurves(8))) Set oDim = oGeneralDims.AddDiameter(oTG.CreatePoint2d(8, 20), oSheet.CreateGeometryIntent(aoDrawCurves(9)), True, False) MsgBox "Create a text box with a leader." ' Place a text box with a leader. Dim oObjColl As ObjectCollection Set oObjColl = ThisApplication.TransientObjects.CreateObjectCollection Call oObjColl.Add(oTG.CreatePoint2d(16.5, 15)) Dim oEval As Curve2dEvaluator Set oEval = aoDrawCurves(4).Evaluator2D Dim adParams(0) As Double adParams(0) = 0.6 Dim adPoints(1 To 2) As Double Call oEval.GetPointAtParam(adParams, adPoints) Call oObjColl.Add(oSheet.CreateGeometryIntent(aoDrawCurves(4), oTG.CreatePoint2d(adPoints(1), adPoints(2)))) Dim oLeaderNote As LeaderNote Set oLeaderNote = oSheet.DrawingNotes.LeaderNotes.Add(oObjColl, "Text with a leader") oLeaderNote.DimensionStyle = oLeaderNote.DimensionStyle End Sub
Karthick
Hi Shiva,
Have you figured your issues out? It should be a Few tweaks in the code to allow it to run in the drawing
Mitch
Hi Mitch,
Yes iam trying to create the section view from a circle drawing curve.
I Attached the sectional view image, which i did manually. So kindly try to fix this error.
Karthick
Hello Mitch,
Thanks for your reply, The code did work for the assembly drawings, but of it does not detect if the the dimension iam looking for is in the actual part and not in the assembly itself. Also the code does not detect the dimensioning between two holes as i said earlier.
Shiva
Hello karthick,
Trying using this code and it should work.
Create a point to draw the the section line
oPoint5 = oTG.CreatePoint2d(-100, 60)
oPoint6 = oTG.CreatePoint2d(100, 60)
oDrawingSketch = oBaseView.Sketches.Add
oDrawingSketch.Edit
oSketchLine = oDrawingSketch.SketchLines.AddByTwoPoints(oPoint5, oPoint6)
oDrawingSketch.ExitEdit
oSectionView = oSheet.DrawingViews.AddSectionView(oBaseView, oDrawingSketch, oPoint7, kHiddenLineremovedDrawingViewStyle,DrawingViewScale)
For the coordinates of the points 5 and 6 choose according to your darwing and play around with it to get the excat position.
Hope this helps you.
Shiva.
Karthick,
Instead of using the circle, try using the MidPoint as your Point Intent to enter into the Section view function. This should Make things a little easier
Shiva,
It might be easier to understand what you're trying to explain with some code or screen shot. If you'd like to provide some.
Regards
Mitch
hello,
in ilogic how can i create sectional views in drawing sheets and detail view also for appropriate positions.
karthick
Hi Karthick,
In my original code I had a function that created Detail Views. If you look there then you should be able to use most of the function and I'm sure you should be able to insert the Section View Code from the API and make a function for that as well from the bases of the code.
Regards
Mitch
I am new for the creation of section view and detail in i-logic. So i need more clarification about the code. I am not able understand your orginal code, its bit of confusing, because you used the your inventor model parameter like (inlet flange, outlet flage). So there iam not getting clearly. So pls guide me.
Karthick
Hi Karthick,
I believe the most helpful thing I can teach you is how to use the Inventor's API if you do not know how to do so.
If you go to the "Tools" tab and click on the "VBA Editor" Button, a new window wwill pop up in Inventor. From here, press F2 and the object browser should open for the API.
Scroll through the classes in the side bar until you come to "DrawingViews," in the main window, a list should come up with all of the possible options that may be used from DrawingViews. You are looking for "AddDetailView." If you select this option by highlighting it and proceed to press F!, a new window will appear with the help options for this function. A description of everything required to use this function will appear here.
Let me know if you need further clarification
Regards
Mitch
1. I create sectional views in Assembly model.
2. In that how to get edge name in assembly model its very confusing to me.
3. Is there any tool, to displays the edge name or sketch name in inventor to make VBA code.
For example: Some of sample VBA program, they use( sketchline 1, drawcurve 1..).how to get these name in existing model.
karthick
Hi Karthick
I believe what you're seeing is code that they create the sketchline in. Since they are creating it, you can name it and keep track of this line if you want to use it in further code. The drawcurve is probably a similar concept.
In my code I created a search engine, where you enter the length of the line, orientation, and other descriptive comments to specify which line you are looking for. If you look back to my descrpition of the CreateLinearDimension, you should be able to understand the type of search engine you'd need to create. You can also refer to the code file for reference in creating your own.
Regards
Mitch
Hi all!
I just want to create a automatic isoview at my first page of my assembly who are at my second page, all with ilogic, anybody abble to help me 🙂
Thanks!
I'm new to all this Ilogic programming and tried your example files provided but have the following error when runnig it:
ERROR MESSAGE
Error in rule: Drawing Automation, in document: Hang_Beam.iam
Paramètre incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
MORE INFO
System.ArgumentException: Paramètre incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Documents.Add(DocumentTypeEnum DocumentType, String TemplateFileName, Boolean CreateVisible)
at LmiRuleScript.CreateDrawing_PlaceViews(String PartNumber, Double DrawingViewScale, String ViewsToPlace, Boolean AssemblyDrawing, DrawingView& oBaseView, DrawingView& oView2, DrawingView& oView3, DrawingView& oView4)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Can you help me?
Actually, what I would like to have is a command button in my ipt and iam files to generate an automatic drawing with the views, proper scaling of the views depending on the sheet size, automatic centerlines, and parts list. All this to minimize the number of clics!! BTW I use Inventor Pro and Vault 2014
